header question
im in a rush trying to take my aftermarket headers off....all bolts are off now the problem is gettin it to come out...do i HAVE to take the crossmember off in order to make the header fit and come out???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Well in that case, jack the car up really high and you should be able to get it off easier that way.
i started to do that..but the way the header is..i think the crossmember is in the way..thats the problem
</TD></TR></TABLE>i started to do that..but the way the header is..i think the crossmember is in the way..thats the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bardo »</TD></TR><TR><TD CLASS="quote">i started to do that..but the way the header is..i think the crossmember is in the way..thats the problem</TD></TR></TABLE>
Then remove it... only 4 bolts and 2 nuts.... You might need to notch that crossmember to make clearance for a header, you'll need to have it off anyway to install a header.
jweezy225
Aug 15, 2004 01:32 PM
