Having trouble installing axles? Try this out!
Old Jul 22, 2004 | 08:21 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Having trouble installing axles? Try this out!
Doing axles on a car is not a hard job; most of the time. Undo a few nuts, swing out the knuckle, and slide the axle into the tranny or intermediate shaft. But sometimes, these ***** just don't want to go in. This job that was supposed to take 15 mins in theory is now taking hours, and numerous objects are getting thrown and beaten. I came up with a solution. I hope this helps many people out.
First, pull the car into a garage, next to a wall. Then take a wooden post, and lay it on the floor, butted up to the wall, parallel in front of the axle. Then take a 2x4, and hold it up in between the piece of wood you just laid down, and the axle. Now comes the fun part! Have someone hold the axle up underneath the kaah, while you hold the second piece of wood up, and beat the crap out of it w/ a BFH (big friggin' hammer for those not in the BFH loop) to make the axle go in. The wooden post holds the second piece of wood in place while you go medevil on the 2x4, and that bastard snap ring on your axle. Here's a pic that demonstrates what I'm talking about. Now go find some wood and a BFH, and make a hot pocket while you're at it.
Old Jul 22, 2004 | 10:00 AM
phatrick2332's Avatar
or a rubber malet taping on the end of the axle while its being twisted, either..or..
Old Jul 22, 2004 | 10:57 AM
suspendedHatch's Avatar
Default Re: (phatrick2332)
Beating the axle in was easy. Getting the axle nut off was the hard part. I had to take it to a tire shop and they had to break out their big air tools since their normal air tools wouldn't do it. And the ******* thing had been removed only a few months ago to do an engine swap.
Old Jul 22, 2004 | 10:03 PM
Mine was easy to take off. I just bent the staked part back out before I removed it.
Old Jul 23, 2004 | 12:10 AM
4DRmafia's Avatar
umm cool idea but lucky i already replace mines but i'll use this new theory for my next replace if it really works
thanks dood
Old Jul 23, 2004 | 03:21 AM
hondaguyef's Avatar
Default Re: (SkipMic2006)
That is how I have always done it
Old Jul 23, 2004 | 10:26 AM
OTT's Avatar
OTT
Or how about holding the driveshaft up with one hand holding and pushing it in (so the inner joint is deep int the 'cup') then using the correct tool, a plastic tipped anti-vibration mallet the drive it in without causeing any damage or messing around with like a plank!
Old Jul 23, 2004 | 11:14 AM
Runnerdown's Avatar
I never use hammers to put in axles. Some thick grease around the snap ring to center it works wonders.
Old Jul 23, 2004 | 11:37 AM
heh, i tried using marine grease on the splines before putting it in, but it didn't seem to help that much.
Dave_Dc2
Sep 23, 2009 11:34 AM
stevenDAtegra
Nov 19, 2008 11:43 AM
bara6075
Oct 3, 2007 04:36 PM
Rob :190:
Feb 22, 2003 08:44 AM
ghettoracer
Oct 6, 2002 02:18 PM
