antenna wire
Look in the drivers kick panel for the wire coming down from the antenna itself. It will be the only black co-ax in there. Once you find it, trace it to the radio hole.
if your replacing the antenna. do not pull out the entire old antenna, you need it inorder to put your new factory antenna back into the car. ill explain if this is what you are doing.
koumatae
Aug 2, 2012 12:53 PM
