O/T what fittings for water temp gauge
Old Jul 21, 2004 | 06:05 PM
mrbsponge's Avatar
Default O/T what fittings for water temp gauge
what fitting and where can you buy it to install an aftermarket water temp gauge in my civic si, is it a metric fitting and can i buyit at a parts store??
Old Jul 22, 2004 | 04:08 AM
mrbsponge's Avatar
ttt
Old Jul 22, 2004 | 08:45 AM
mrbsponge's Avatar
ttt nobody
Old Jul 22, 2004 | 09:24 AM
Bnjmn's Avatar
Default Re: O/T what fittings for water temp gauge (mrbsponge)
Easiest thing to do is to install a brass "T" fitting inline with the water lines that go to the throttle body. Just buy some longer line from a car parts store and be sure to mount the tee in a way that will ground it. Either the water temp sensor or the brass tee that it is attached to must be grounded for the gauge to work. Just use some metal strap material and you'll be all set.
Ben
streetcartuner
Jan 12, 2008 09:59 AM
5genhatch
Dec 28, 2004 03:50 PM
