abs light came on... one last try....
Old Nov 25, 2001 | 07:48 PM
Bklyn TSi's Avatar
Banned
Default abs light came on... one last try....
ok i noe there's like 54,321 topics posted about this, but i seriously could use some help...
couple of days ago my abs light came on while the car was warming up, like 5 minutes into the car started.. the day after it was fine, abs light didnt' come on at all. but since then it has been coming on a couple of minutes after the car started every single time now.
i dont' know if it has anything to do with the weather, but the temperature dropped belowed 0 that night when the abs light first came on.
i searched through all the treads here, did everything as advised: checked break fluid level, reset ecu, pull abs fuse and put it back in, push the button on the dash... still no help =T anything else i can do before i have to bring it into the dealer?
any help would be appreciated... thanks in advance.
Old Nov 26, 2001 | 07:24 PM
Bklyn TSi's Avatar
Banned
Default Re: abs light came on... one last try.... (Stony TSi)
ttt.. anyone?
Old Nov 26, 2001 | 07:50 PM
BreakStuff's Avatar
New User
Did you check the fluid level in the ABS unit and not the master cylinder?
You have a blue 2 pin connector underneath the glove box the will display ABS trouble codes when the connector pins are jumped together.. this would be a good starting point.. trouble code will be indicated by the flashing ABS light....
Old Nov 27, 2001 | 04:11 AM
Bklyn TSi's Avatar
Banned
Default Re: abs light came on... one last try.... (BreakStuff)
where is the ABS unit fluid level? I'm sorry but I can't find it in the manual....
Old Nov 27, 2001 | 05:49 AM
urbanlegend21's Avatar
New User
looking from the front of the car the ABS unit is at the front right of the car the mark is at the front of the resevoir
my ABS does the same thing but I don't use it so I just ignore it
Old Nov 27, 2001 | 06:21 AM
MrBite's Avatar
If the parking brake was up, even just one click, your ABS will disable after you drive it for a little bit. Sorry if you already know this, but sometimes it's the silly stuff, not a crazy complicated ABS faliure thing good luck!
Oh wait, I forgot this wasn't the integra forum sorry
[Modified by MrBite, 10:22 AM 11/27/2001]
Old Nov 27, 2001 | 06:55 AM
mercury's Avatar
New User
My friend has a '95 Accord EX auto. ABS light came on. Turned out to be a busted pump, the thing under the hood with all the brake lines going in and out of it. Not cheap to replace...
Does your ABS still work?
Old Nov 27, 2001 | 08:05 AM
Bklyn TSi's Avatar
Banned
Default Re: abs light came on... one last try.... (mercury)
i don't know if it still works... should i test it out in a parking lot? i looked through my hayne's manual for troubleshooting it, turns out they don't cover ABS systems... =T
Old Nov 27, 2001 | 09:01 AM
mercury's Avatar
New User
Yeah, just go test it out. It'll be pretty obvious if it's working or not. Go fast, floor the brake pedal. If it chatters, ABS is ok. If your wheels lock and you skid, your ABS is gone.
You're looking at about $300 for a used or refurb part and a couple hours of labor. The new part costs near $1000. Or you can just flip the bird to ABS and drive without ABS like everyone used to in the '80s.
Bsharpe
May 8, 2009 03:33 AM
DC231_01
Jun 26, 2006 08:37 PM
CNSK
Apr 12, 2003 11:13 PM
forksports
Oct 20, 2001 11:14 AM
redteg1
Aug 18, 2001 02:42 PM
