ECU code 1
Old Jul 21, 2004 | 04:57 PM
NYSiRacer's Avatar
Default ECU code 1
Hi, I have a '90 Si, and my CEL comes on every time after driving for a while (30 minutes)
The ECU short blinks once, so I replaced the O2 sensor; however, it still comes on as before.
The distributor, spark plugs, and spark plug wires were also recently replaced; the alternator, however, is making noice.
Please advice, thanks very much.
Symptoms:
When the CEL comes on, it feels like the car is choking (it shakes, and it accelerates a lot slower) The RPM needle moves up so slow even when I gas hard. It's as if it lacks of air or fuel.
Old Jul 21, 2004 | 10:07 PM
NYSiRacer's Avatar
Anyone?
Old Jul 21, 2004 | 10:12 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (NYSiRacer)
if you replaced the o2sensor then you could have a short or loose conection.
Old Jul 22, 2004 | 06:08 AM
chris_m's Avatar
* B A N N E D *
Default Re: (JC18)
Did you get an o2 with a plug or did you have to add your old plug. o2 wiring needs to be soldered not butt connected.
Old Jul 22, 2004 | 07:02 AM
manson's Avatar
Default Re: (alld16a)
o2 just like everyone said. check connections, reset ECU, if problem continues buy an o2 install call it a day.
Old Jul 22, 2004 | 10:23 AM
NYSiRacer's Avatar
I bought a new o2 with a plug, and I just plugged it in. It only has 1 wire.
Could a bad fuel injector, or even a bad idle controller that's causing this?
Old Jul 22, 2004 | 11:18 AM
hatchinprogress's Avatar
i think a code 1 is a bad ecu try another ecu in your car and see if the codes stops
Old Jul 22, 2004 | 11:48 AM
NYSiRacer's Avatar
Default Re: (hatchinprogress)
I thought code 0 is bad ECU... According to https://honda-tech.com/zerothread?id=468260 , code 1 is o2 sensor?
Old Jul 22, 2004 | 04:39 PM
chris_m's Avatar
* B A N N E D *
Yes code 1 is o2. Clear the ecu disconnect the battery for 20 seconds and see when the light comes on.
Old Jul 23, 2004 | 06:43 AM
NYSiRacer's Avatar
I've already done that 3 times, and the CEL still comes on after 15 - 30 minutes of driving.
Old Jul 23, 2004 | 06:49 AM
tilt's Avatar
Default Re: ECU code 1 (NYSiRacer)
what brand o2 did you buy? a crappy one might be giving you problems.
i believe bosch is closest to oem you can get without shellin out the mad cash
Old Jul 23, 2004 | 02:43 PM
NYSiRacer's Avatar
Default Re: ECU code 1 (tilt)
I bought a regular aftermarket o2 sensor... Any chances that other things could have caused this? I think that I have a bad injector or idle controller because my idle is not stable either.
Old Jul 23, 2004 | 02:46 PM
tilt's Avatar
it's prob not too far fetched
maybe try this first:
https://honda-tech.com/zerothread?id=699787
Old Jul 29, 2004 | 05:19 PM
NYSiRacer's Avatar
That fixed my unstable idle problem. Thanks.
However, I still get code 1; I even replaced another new o2 sensor. What else can cause code 1? I'm pretty sure that the o2 & the ECU are good as well as the connection...
sherrybogue
Jul 30, 2013 05:11 PM
951dc5
May 22, 2006 05:52 AM
Leviata-N
Oct 28, 2004 09:54 AM
hatchman92
10
Oct 9, 2002 07:19 PM
