quick help/brain fart: i want to raise the car, which way do i adjust the springs???
Old Jul 21, 2004 | 04:20 PM
done's Avatar
Default quick help/brain fart: i want to raise the car, which way do i adjust the springs???
bout to leave for expo and want to raise the car for the ride, do i compress the springs, or do i turn it to let the springs elongate themselves?
Old Jul 21, 2004 | 04:22 PM
done's Avatar
Default Re: quick help/brain fart: i want to raise the car, which way do i adjust the springs??? (Jordo)
which way to i turn the coilovers im lost
right or left?
Old Jul 21, 2004 | 05:41 PM
Phoenix_ITR's Avatar
move the perch UP the shock -- so that would be compressing the springs.
Old Jul 22, 2004 | 10:26 AM
AamirCWITR's Avatar
Default Re: quick help/brain fart: i want to raise the car, which way do i adjust the springs??? (delinquen
turn clockwise to raise, when i say turn clock wise i am assuming you have adjustable threaded body coilovers and its the lower body that you are moving....
Modified by AamirCWITR at 8:20 PM 7/22/2004
Old Jul 22, 2004 | 10:43 AM
kruthles's Avatar
righty tighty, lefty loosey
Old Jul 22, 2004 | 10:48 AM
mugenracer's Avatar
by screwing them up to raise the car your increasing the pre-load and so stiffening the springs which will not help the ride comfort, in fact it will possibly make it worse! That is unless you have helper springs to take the pre-load...unfortunately i dont and therefore having the car sat lower increases the comfort a bit!
Old Jul 22, 2004 | 10:50 AM
MattD@Stoptech's Avatar
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">by screwing them up to raise the car your increasing the pre-load and so stiffening the springs which will not help the ride comfort, in fact it will possibly make it worse! That is unless you have helper springs to take the pre-load...unfortunately i dont and therefore having the car sat lower increases the comfort a bit!</TD></TR></TABLE>
My brain hurts.
Old Jul 22, 2004 | 11:22 AM
PM-Performance's Avatar
im sure he means so he doesnt rip his front end off on the shitty roads on the way there.
anyway Jorod since it doesnt look like you have gotten the right answer yet. counterclock wise is up , and clockwise is down.
peatear01
Suspension & Brakes
14
Feb 14, 2011 07:59 AM
CLIPHSET
Suspension & Brakes
Sep 9, 2009 01:58 PM
realxfresh
35
Aug 16, 2009 04:51 AM
IAcivicEK
Suspension & Brakes
12
Jun 7, 2007 10:02 AM
rnl04
Apr 16, 2004 02:30 PM
