does anyone else have a hard time starting.....
Old Jul 21, 2004 | 03:34 PM
AllmotorJunkie's Avatar
Default does anyone else have a hard time starting.....
does anyone else have a hard time starting their integras besides me? Every morning, I have the hardest time starting my Integ. Sometimes it takes me 5 minutes to get it to start. It cranks fine but just won't start. Once I get the initial start, the car starts fine after that. It happens when I leave the car over night and start it the next morning. The problem has been around for a while now...
Anyone have any ideas as to what might be....
thanks
Old Jul 21, 2004 | 04:27 PM
sabotage7's Avatar
Default Re: does anyone else have a hard time starting..... (AllmotorJunkie)
dont quote me on this, but i've heard of people having problems starting w/a lightweight flywheel.
Old Jul 21, 2004 | 04:46 PM
ElectronBlueGsr1.8's Avatar
my 97 gsr does the same thing sometimes expecially when it is low on gas.....try cutting the key on for a few seconds not turning the starter but just cut the key on all the way then cut it all the way back and then cut it on again and then try to start it let the fuel pump get nice and primed up......
Old Jul 21, 2004 | 04:56 PM
Lewie's Avatar
I'm here for the gangbang!
Default Re: does anyone else have a hard time starting..... (ElectronBlueGsr1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ElectronBlueGsr1.8 &raquo;</TD></TR><TR><TD CLASS="quote">my 97 gsr does the same thing sometimes expecially when it is low on gas.....try cutting the key on for a few seconds not turning the starter but just cut the key on all the way then cut it all the way back and then cut it on again and then try to start it let the fuel pump get nice and primed up......</TD></TR></TABLE>
Exactly what I was thinking. I have the same problem when I am low on fuel.
Old Jul 21, 2004 | 05:00 PM
cyr0ch's Avatar
Default Re: does anyone else have a hard time starting..... (Lewie)
it does sound like a fuel problem, whether it takes a moment to pump to the injectors, or if something is not working properly, such as a fuel filter going bad, or even worse, a fuel pump. Just some ideas.
[ iLL ] iNt3GrA's Avatar
yeah when im low on fuel i get that, when i turn the key and wait a few sec then start it, it starts right up
Old Jul 21, 2004 | 07:23 PM
Cliffjumper2's Avatar
Default Re: ([ iLL ] iNt3GrA)
yep, same here, when it's lower than a quater tank, it cranks for a bit before starting, but never does it when I have at least half a tank.......I'm thinking I'll eventually need a new fuel pump, or clean out my tank.
but I did do something that helped recently. When I changed my oil I put a full tank of gas along with an stp fuel injector cleaner, and the I took it for a nice long ride to maryland and back keeping it at about 80mph/4,000 rpm.......used up the whole tank, and it hasn't happened in a week.
Old Jul 22, 2004 | 11:44 AM
cyr0ch's Avatar
Default Re: (DCcliffjumper2)
great idea. it definitely never hurts to use a fuel injection cleaner. the best is BG 44K, although it is $20 per can.
mister.wong
Sep 13, 2008 04:45 PM
N1NjA TuRtLE
Aug 26, 2006 06:15 PM
JDM_rolex
Aug 14, 2006 09:30 AM
Quade
Oct 21, 2004 07:55 AM
Beat2Shit
Jun 7, 2004 09:42 PM
