Rebuilding my motor
Old Jul 21, 2004 | 03:33 PM
00siALLmotor's Avatar
Default Rebuilding my motor
Sup guys.... I am rebuilding my motor (b16)... I already bought CTR pistons, will have my stock rods shotpeened, and just bought some new dual ITR valve springs, and ITR cams... and on top of that, will get a Hondata to tune it all... What do you guys think? Any suggestions or comments would be helpful...
Thnx...!
Old Jul 21, 2004 | 05:02 PM
Sikocivic's Avatar
Default Re: Rebuilding my motor (00siALLmotor)
I would not waste the time and money to shot peen your stock rods. I would go with a set of aftermarket rods. If you are going to all the trouble to rebuild the motor, do it right and upgrade the rods.
Old Jul 25, 2004 | 11:50 AM
Fleas_Ef's Avatar
Default Re: Rebuilding my motor (Sikocivic)
props man i havethe exact set up, cant wait till its all done how much was it to get the rods shot peened?
Old Jul 25, 2004 | 12:03 PM
Full Race A6's Avatar
Default Re: Rebuilding my motor (B16Power)
If your going all motor you can do whatever yuo want with the rods, but if you plan to boost/spray, Id upgrade them. There fairly cheap new @ around $300
Im also building a motor right now
Dont forget about the crank, balanced, micropolished and make sure it isnt out of round
All new rings/bearings
Old Jul 25, 2004 | 12:19 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">I would not waste the time and money to shot peen your stock rods. I would go with a set of aftermarket rods. If you are going to all the trouble to rebuild the motor, do it right and upgrade the rods. </TD></TR></TABLE>
looking at the parts he is adding A/M rods=overkill
Old Jul 25, 2004 | 01:01 PM
spaceman's Avatar
Default Re: Rebuilding my motor (temp)
ya dood you dont need rods..make sure you get the correct parts and install them right,take your time on it..good luck
Old Jul 25, 2004 | 04:42 PM
CRXBart's Avatar
I have that same setup for sale for you cheif. CTR pistons on modded rods, because you have to shave 1mm off each side but you probally knew that. The cams I have are CTR better intake cam. There is no need to buy new rods though just shave 1mm off each side. Oh yeah I got crower valve springs and retainers in mine for sale also.
Old Jul 25, 2004 | 06:24 PM
temp's Avatar
Default Re: Rebuilding my motor (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">I have that same setup for sale for you cheif. CTR pistons on modded rods, because you have to shave 1mm off each side but you probally knew that. The cams I have are CTR better intake cam. There is no need to buy new rods though just shave 1mm off each side. Oh yeah I got crower valve springs and retainers in mine for sale also.</TD></TR></TABLE>
unless he is talking about 2000-01 ITR cams
Old Jul 26, 2004 | 12:49 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
unless he is talking about 2000-01 ITR cams </TD></TR></TABLE>
I was not aware of the change in '00 are they the same as my CTR cams or better?
Old Jul 26, 2004 | 01:34 AM
hahagasdcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">I was not aware of the change in '00 are they the same as my CTR cams or better?</TD></TR></TABLE>
They are the same....
Motor should run good with stock rods unless you plan on spray or boost.
Old Jul 26, 2004 | 04:49 AM
crx_88_si's Avatar
did you do the machining on the block already? I hope you got over-sized CTR pistons.
Cynical 1
Feb 8, 2012 01:31 AM
f20b jones
12
Dec 23, 2010 09:12 PM
xfrankx
Mar 28, 2005 03:24 PM
01ITR#700
Aug 15, 2003 11:45 AM
DS1
Sep 9, 2002 10:49 AM
