anyone know how to rebuild an A/C compressor?
Old Jul 21, 2004 | 03:13 PM
hondaZvic's Avatar
Default anyone know how to rebuild an A/C compressor?
just like it says? can they be rebuilt?
mine is dirty inside, and i know it works. its been sitting in the shed for about 2 years uncovered. i know it works, i just dont wanna put it on and then it seize up or break cuz of some dirt in there..
i would like to take it apart and clean it thoroughly. any advice? or just go at it?
Old Jul 21, 2004 | 07:50 PM
hondaZvic's Avatar
Default Re: anyone know how to rebuild an A/C compressor? (hondaZvic)
maybe the late night crew will know...?
Old Aug 16, 2004 | 08:42 PM
murmur9's Avatar
bump... cant they?
or can you just replace the wheel that turns or the bearings inside
Old Aug 16, 2004 | 10:09 PM
eda6's Avatar
I'm an hvac service tech.
I do light industrial and commercial ac.
I don't do cars because i don't have an ac in my hatch, but i know about compressor rebuilds.
How much is a new compressor?
Take your compressor to an ac shop and see what they say.
I'd get a new compressor if i was you. I imagine the system has been exposed to the elements for the last two years. familiarize yourself with the piping and flush out flush the system with nitrogen (do not use oxygen, at 5 lb of pressure it can explode).
If you do decide to attempt this make sure there's refrigerant oil in the system (not motor oil). Your compressor relies on refrigerant and oil to keep it cool. If your short on one of these expect problems.
Get a new receiver/drier. Recharge system.
i'd also monitor that drier and plan on changing it a few times because that's where most of the garbage in the system will end up. Eventually it will be clean
im me if you got ?'s
Old Aug 17, 2004 | 06:48 AM
hondaZvic's Avatar
Default Re: anyone know how to rebuild an A/C compressor? (eda6 hb)
cool thanks.
is there any way to "flush" out the compressor?
baybay
Aug 26, 2018 02:39 PM
threeoten
Honda Civic (2001 - 2005)
Aug 10, 2016 08:31 PM
Underlook
Jul 14, 2013 06:05 PM
c1civic
May 1, 2007 06:12 PM
erikiksaz1
Sep 24, 2004 07:50 PM
