civic turbo upgrade
Old Jul 21, 2004 | 01:28 PM
civiceg500's Avatar
Default civic turbo upgrade
I am goin to run on a T3 turbo at 8 psi on a stock D15b7 what things should i get for it to run smooth and safe?
Old Jul 21, 2004 | 01:38 PM
EJ1 wilcox's Avatar
Default Re: civic turbo upgrade (civiceg500)
Let's start with...what do you currently have?
which turbo?
fuel management?
etc...
etc...
Old Jul 21, 2004 | 01:50 PM
jeffk182's Avatar
Uhmm your gonna need some new internals if you want to be SAFE, fuel management, boost controler, reccomend blow off yadayada all the typical turbo accessories.
Old Jul 21, 2004 | 01:56 PM
Louie_EM1
Guest
Posts: n/a
Default Re: civic turbo upgrade (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Let's start with...what do you currently have?
which turbo?
fuel management?
etc...
etc...
No, let's start with a motor instead of a hamster wheel.
You're going to run a T3 snail at 8psi (...right); but you don't know what will make it run smooth/safe?
you obviously didn't do your research.
First, I suggest a motor, and building from the inside.
Old Jul 21, 2004 | 03:09 PM
dohcMONSTER's Avatar
Default Re: civic turbo upgrade (Louie_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
First, I suggest a motor, and building from the inside.</TD></TR></TABLE>
good point, read and research
Old Jul 21, 2004 | 03:28 PM
EJ1 wilcox's Avatar
Default Re: civic turbo upgrade (sohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">good point, read and research</TD></TR></TABLE>
Yes!
Start with Maximum Boost, by Corky Bell...
That should tell you everything you need to know!
By the way, you don't really need to build your engine if you are planning on running low boost...
according to Maximum Boost, "with currently available fuels, 7 to 12 psi boost is a practical upper limit for stock engines (at sea-level elevation)."
About engine durability it says, "...you can expect about 90% of normal engine life."
Old Jul 21, 2004 | 03:57 PM
specv5150's Avatar
Default Re: (jeffk182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffk182 &raquo;</TD></TR><TR><TD CLASS="quote">Uhmm your gonna need some new internals if you want to be SAFE, fuel management, boost controler, reccomend blow off yadayada all the typical turbo accessories.</TD></TR></TABLE>
LOL
Ummmm no. People run kits with no internal upgrades and have success.
Old Jul 21, 2004 | 04:26 PM
toolowsol's Avatar
Default Re: (specv5150)
if you want to turbo and be safe, you need to do more research, simple as that, you'll know when your ready to safely turbo, because you will be able to answer your own question
Old Jul 21, 2004 | 04:39 PM
vansprinkle's Avatar
Default Re: (toolowsol)
there are a lot of pieces to a turbo kit other than the turbo itself. piece together all the little crap and get hondata. take it somewhere who does really good dyno-tuning and get it tuned properly, this will determine the life of your engine. my friend had a stock b20 in his eg hatch (daily driven) with a t3 turbo and he ran low 12's for about 2 years on 9-12 psi, didnt have many problems with it at all, he just kept up with the maintanence.
Old Jul 21, 2004 | 05:10 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">... you'll know when your ready to safely turbo, because you will be able to answer your own question</TD></TR></TABLE>
So true....so true indeed
teddy_dc2
Jul 26, 2007 03:50 PM
projectef
Jul 3, 2007 08:35 PM
CustomX113
Nov 20, 2006 09:27 AM
CaptainMorgan
Feb 15, 2004 06:24 AM
AsianMullet
Oct 25, 2003 11:56 AM
