IAB wiring help please
Old Jul 21, 2004 | 11:55 AM
integmester's Avatar
Default IAB wiring help please
Im dropping in a b18c1 into a 96 hatchback. I am using a 98 EX wiring harness. I followed the IAB wiring directions on HybridHonda website, but I noticed as I was running the wire to the IAB sensor there was 2 pins. So where the 2nd pin connect to? Is that 2pin suppose to be a ground wire or does it hook up to the ECU? Help please.
Old Jul 21, 2004 | 03:32 PM
showtymers619's Avatar
* B A N N E D *
Default Re: IAB wiring help please (integmester)
you can just ground it
Old Jul 21, 2004 | 05:08 PM
ZigenBallz's Avatar
Default Re: IAB wiring help please (ShowTymers619)
I thought the ground was a switched ground thru the ECU and the 2nd wire, don't know what colors you are dealing with but mine is pink goes to a switched 12v source...
just hook the vac hose on the diaphragm straight to the manifold... works better IMO...
Old Jul 22, 2004 | 04:36 AM
JimBlake's Avatar
Default Re: IAB wiring help please (ZigenBallz)
https://honda-tech.com/zero...25107
RIZOBIZERT
Feb 28, 2008 12:25 PM
Hung_Lo
Jun 17, 2007 06:55 PM
RACEPAK
Dec 6, 2004 12:08 AM
integmester
Jul 22, 2004 04:26 AM
kuelerz
Oct 4, 2002 10:38 AM
