What MM for this sensor?
Old Jul 21, 2004 | 11:12 AM
MooreBoost's Avatar
Default What MM for this sensor?
I need to know what MM socket to use on the green sensor. It is the sensor to the upper left of the oil cooler, not the oil pressure sensor, but something else.
Old Jul 21, 2004 | 11:16 AM
hondacivic_si's Avatar
Default Re: What MM for this sensor? (tegunderpressure)
Why don't you just do a hit and miss type deal instead of trying to ask people? You would be able to figure it out faster if you just tried one.
Old Jul 21, 2004 | 11:18 AM
MooreBoost's Avatar
Default Re: What MM for this sensor? (hondacivic_si)
I dont have one that large, I know its larger than a 21mm. The sets of multiple sockets past that size are 50 bucks, and single sockets that large are 5. So I dont feel like paying that much in hopes that I buy the right socket.
Old Jul 21, 2004 | 11:21 AM
Ok, I understand it now
Old Jul 21, 2004 | 11:25 AM
520_Motorsports's Avatar
If I remember right it is a 7/8 or a 1" socket or wrench
Old Jul 21, 2004 | 11:26 AM
MooreBoost's Avatar
Ive been told 24 or 27, can anyone confirm either?
Old Jul 21, 2004 | 11:36 AM
APEX CRX's Avatar
can't confim but I used a big channel lock plier to get mine off
Old Jul 21, 2004 | 11:47 AM
Rywire's Avatar
Default Re: What MM for this sensor? (APEX CRX)
Ya man, a adj wrench should work fine.
Old Jul 21, 2004 | 12:51 PM
MooreBoost's Avatar
Default Re: What MM for this sensor? (droppedcrxsi)
I cant get an adjustable in there, its just too tight.
24mm wont fit.
Old Jul 21, 2004 | 01:09 PM
Rywire's Avatar
Can you get an adjustable on there, just to get it to size, and bring it in to the parts store.
Old Jul 21, 2004 | 01:42 PM
MooreBoost's Avatar
Nope, wont fit at all. I will have to use a deep socket that atleast one extender with my ratchet. Its really far recessed into the block.
Old Jul 21, 2004 | 01:58 PM
johnzm's Avatar
i used a 32mm and it was a loose fit, but it isint like its torqued past 15lbs anyways
Old Jul 21, 2004 | 09:10 PM
MooreBoost's Avatar
Default Re: What MM for this sensor? (johnzm)
Bump for the night, maybe its the 27mm?
Old Jul 21, 2004 | 09:21 PM
eda6's Avatar
1 inch=25.4mm
see if you can get a dial caliper on there and get a measurement.
Old Jul 21, 2004 | 09:40 PM
Jester88Si's Avatar
its 1 1/16'' inch i think because I bought a socket just for this sensor in particular dont take my word for it though I would have to go look at the socket to confirm it..
Old Jul 21, 2004 | 11:13 PM
hahagasdcrx's Avatar
Default Re: (Jester88Si)
Just measured my extra one with a digital caliper. You need a 27mm deep socket to remove it. Measured out to be 26.80mm or 1.055" so take your pick.
Old Jul 22, 2004 | 07:48 AM
MooreBoost's Avatar
Default Re: (hahagasdcrx)
Thank you hahagasdcrx!
Matt_Jagg7
May 13, 2010 05:12 AM
RNPoo7
Mar 18, 2006 08:50 PM
Roi
Nov 20, 2005 09:56 AM
RACEPAK
17
May 19, 2005 04:53 AM
