Problems with guage cluster and climate controls
Old Nov 25, 2001 | 05:29 PM
ARunto's Avatar
Default Problems with guage cluster and climate controls
I'm having a problem where my guage cluster and climate control lights turn on and off. It seems to happen randomly. I'll have my lights on and then all of a sudden the guage cluster and vent contol lights go out. Sometimes with a tap on the dash they will come back on and sometimes not at all. The only lights that work are the high beam indicator, left and right turn signal indicator. Is there a relay I should look for that might be going bad? It does it more often when the weather is cold. Any input would be appreciated.
-Alan
Old Nov 25, 2001 | 06:13 PM
nfn15037's Avatar
Default Re: Problems with guage cluster and climate controls (ARunto)
Damn, i have the same problem, except its only the climate control lights. WTF is that? ANy other Teg owners have a similar prob and how do we fix it??? TIA
Old Nov 25, 2001 | 06:31 PM
Cosworth's Avatar
Default Re: Problems with guage cluster and climate controls (nfn15037)
I know that happens when the fuse is faulty. It also seems possible that a lose wire or two is shortening the circuit. What year is your 'teg?
Old Nov 25, 2001 | 07:33 PM
ARunto's Avatar
Default Re: Problems with guage cluster and climate controls (Cosworth)
Mine's a '95 GSR.
-Alan
Old Nov 25, 2001 | 08:05 PM
nfn15037's Avatar
95 GSR too.
Old Nov 25, 2001 | 10:48 PM
ITR 2K's Avatar
Might be the alternator. Same thing happened to my old EG, and it was the alternator.
Old Nov 25, 2001 | 10:57 PM
gsr98vtec's Avatar
Default Re: Problems with guage cluster and climate controls (ITR 2K)
check for a lose connection in your dimmer...this happened to me also and the dimmer had a loose wire...same symptoms as you guys, i would hit a bump and lights out...hit another and lights back on...just check the fuses first and then if its not that pull out the dimmer which is easy and check the wiring
Old Nov 26, 2001 | 10:22 AM
Sam's Avatar
Sam
Default Re: Problems with guage cluster and climate controls (gsr98vtec)
what & where is the dimmer? I have the same problem on my ITR too
Old Nov 26, 2001 | 11:00 AM
gsr98vtec's Avatar
Default Re: Problems with guage cluster and climate controls (Sam)
the little **** to the right of the steering wheel...it controls how bright the cluster and climate control lights are
Old Nov 26, 2001 | 04:12 PM
ARunto's Avatar
I found my problem turns out one of the wires on the dimmer plug was halfway out. Plugged it back in and voila it worked like a charm. Thanks for the input fellas.
-Alan
Old Nov 27, 2001 | 03:23 AM
integra81's Avatar
New User
my climate contorl lights do the same excact thing
Old Nov 27, 2001 | 05:58 AM
TurboITR's Avatar
Default Re: Problems with guage cluster and climate controls (integra81)
its your damn spoon cluster sell that POS to me
Old Nov 27, 2001 | 08:21 AM
ARunto's Avatar
Default Re: Problems with guage cluster and climate controls (TurboITR)
Haha...should of jacked it while you had a chance LOL!!
-Alan
Old Nov 28, 2001 | 09:55 AM
gsr98vtec's Avatar
hehe, damn dimmer causing all of these problems...see what a little loose wire can do
aleks777
Feb 4, 2016 08:52 AM
Oknoe.
Apr 1, 2010 11:29 AM
SPOOLINmatt
Mar 31, 2008 09:51 PM
OPTION2ek V.2
13
Jan 19, 2007 08:00 PM
Nural
Oct 25, 2006 08:00 AM
