T70 too big for h22a Accord
You think a T70 is too big for h22a, heres the stats on the turbo. Should i keep it or go with somethign smaller. Its gonna be pushing 10-12 till i get some type of EMS but it will be ran with a AVC-R.
http://www.clubhonda.com/forum...12883
It would be too big for what you're doing. Especially only 10-12 psi. On a drag car running higher boost, it would work. Couple of friends run T70's, but they're on Supras and even with the larger displacement, there is lag.
like i said before. IMO even for the higher boost you said you wanted to run, i think its too much . POst some pics and link to the official specs from the manufacturer a few people been asking about this turbo this week .
is that the Super 70 from ebay. That turbo will spool some what decent its not that large of a turbo. its super 70 wheel not a true t70 wheel
thats why i wanna see a link from the manufacturer . i heard SS Autochrome sells them or something. if its the same one it should be somewhat ok
Pete he posted it up on the other website i am sure it is the stone mountrain/SS auto piece
I just got my turbo in, a T70, its a big azz turbo, bigger than what i expected.. Heres the stats..
Wet floating ball bearings
Shaft & Wheel Trim 64.5mm
Compressor wheel Super 70 60.5mm
Turbine housing A/R .84
Compressor housing A/R RATIO .70
oil colled
V-Band flange
Think the h22a will spool it up decently. Im gonna be running 10-12 psi on it till i can get some type of EMS.
oil colled
V-Band flange
yeah i got it from ssautochrome on ebay.. Well a friend bought it with his b series setup that they sell that comes with turbo,wastegate and b series manifold, and i just bought the turbo off of him so i was curious about the spool up.. I got it dirt cheap so if anything ill just get another one. I just figured pushing 18psi it would be ok
hope u like boost creep, blown turbo seals ect!! SSautochrome crap
Cuz u will get alot of it!! BTW I hope your bottom end is built. Cuz if its stock then u will be driving to work!!!
that is a big turbo, i think to much for a h22, with 10 or 12 pounds. My t3t4 does nice with my h22. But if you need a deel on a turbo or any parts let me know i know people every where and a turbonetice dealer, so i couuld hook you up.
its not gonna e only 12psi thats till i can get a EMS then gonna do 15-20psi. I was looking over the price and even thought about building the head to rev out more
