Broken axles with slicks?
Old Jul 21, 2004 | 07:01 AM
knalige's Avatar
Default Broken axles with slicks?
Is that (Broken axles if you use slicks) a definite thing or is it a rare situation?
I ask because i was interested in buying some slicks because i've got some stealies on order....and wanted to know if it'd just be easier...cheaper...safer to just get drag radials...
...the safe way out i guess
Old Jul 21, 2004 | 07:12 AM
RTW DC2R's Avatar
a lot of power, and slicks, can break stock axles. slicks with stock or close to stock power shouldnt be a problem. you probably dont need slicks with stock or close to stock power anyway. Id just run drag radials if I was under 200whp.
Old Jul 21, 2004 | 07:33 AM
knalige's Avatar
Default Re: (RTW DC2)
thanks
Old Jul 21, 2004 | 07:36 AM
PM-Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">a lot of power, and slicks, can break stock axles. slicks with stock or close to stock power shouldnt be a problem. you probably dont need slicks with stock or close to stock power anyway. Id just run drag radials if I was under 200whp.</TD></TR></TABLE>
I disagree. improper set up suspension and too much traction breaks axles. its the quick jolt of the power and the tired actually hooking up waaayyy too hard breaks them . Same thing on drag radials. i broke a set on radials the other week. was the 1st time i got traction off the line ever. lol
safest bet to do is launch high and work your way down for the perfect launch on slicks without breaking things. i know people who have ran 550+whp on 25inch slicks on stock axles
Old Jul 21, 2004 | 07:40 AM
RTW DC2R's Avatar
I was implying the same. with slicks, you have traction. with high power, and slicks (traction), axle goes snap. yes it can be done with drag radials. it can be done with street tires. add motor mounts, and that puts even more shock on the axles. suspension setup also plays a part. the list goes on and on, fact is that there are many variables involved.
Old Jul 21, 2004 | 07:48 AM
key is . . . . IF YOU GET TRACTION. thats why i will always suggest to drop the clutch at a higher RPM to slide the car off the line . i rather spin a little than hook too hard and break or hook hard and bog like hell. there is a deffinate technique thats for sure.
Old Jul 21, 2004 | 08:54 AM
splitime's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">key is . . . . IF YOU GET TRACTION. thats why i will always suggest to drop the clutch at a higher RPM to slide the car off the line . i rather spin a little than hook too hard and break or hook hard and bog like hell. there is a deffinate technique thats for sure. </TD></TR></TABLE>
I can attest to the hook hard and break stuff format. I know squat about drag and was launching the car at the strip at around 4500rpm, basically dumping the clutch with the barest hint of feathering.
At rt66 in Joliet, IL... i finally hooked too well. I hooked up and SNAP, just sat there. Found the culprit later, axle sheared in half before the outer CV joint.
If I ever go back for better times, I'll be launching high and sliding off the line instead of hooking. I was pulling down to 2.1 60fts though poor es100s
I was on street tires.... a well prepped track is an amazing thing.
Old Jul 21, 2004 | 09:02 AM
RTW DC2R's Avatar
you gotta find the happy medium. it depends very much on your set up. dumping the clutch and spinning the tires off the line with a stock ITR and your 60fts are gonna be like 2.5 and probably high 14s at best, more likely low 15s. so many factors involved. practice makes perfect. unfortunately practice = breaking stuff = $$$
B18C5_VTEC
Jul 2, 2007 03:32 PM
turbogsr181
Sep 24, 2006 06:40 PM
JDMlyfestyle
Jul 14, 2004 12:27 PM
bubbahatch92
Feb 5, 2004 09:38 AM
ACRXGuy
Apr 2, 2003 12:20 PM
