I've the choice between .....
hello, I have a B16A2 (SirII in us i think) and some modifications above, ECU OBDI P30 with chips home made with rev-limit 8800 rpm, Cam CTR, valve spring CTR, intake manifold AEBS, CAI J&R, head port and polish with 11.0cr and more.... my question is:
I've the choice between two throttle body. either are type R 62mm polished, or a JG 65mm. which of the 2 advise me? and which is advantage and of disadvantage of the 2?
thanks
thanks
I would honestly go with the 65mm and port match it to the intake manifold
you will have better throttle response and you will have more air available to feed the better flowing cams
JDMluvDSMkila
Jan 30, 2012 11:36 PM
SpeedImage3
May 21, 2005 08:39 PM
b16a1civichb
May 6, 2003 07:27 AM
