Maybe a stupid question
Old Jul 20, 2004 | 11:34 PM
Synth124's Avatar
Default Maybe a stupid question
91' honda crx 1.5L dpfi
Info: I just put her in, full rebuild. Head was inspected and fixed and parts replaced as needed. I do have oil PSI around 25. I do have anti-freeze in the system along with new water pump. Just replaced head gasket too. Machine shop used white lithium grease for assembly of the head. I understand the problem below sounds like a blown head gasket but read above.
Problem: I crank the engine over(timing is perfect), white puff of smoke. I let her run at idle(1,200k JUST FOR NOW), still white smoke, however less. Driver her around the block, good amount of white smoke(enough for any driver to get really pissed)
Question: Are there any lines that I switch up that will allow small traces of anti-freeze into the cylinder(s ) without causing any signs of backfire/miss fire or internal damage? Also any other ideas on how and why I could be having this white smoke issue?
As for the whole whether or not my h/g sealed right, I don't have the means or money to get a cylinder leak down test
Thanks and Peace
Synth
Old Jul 21, 2004 | 05:46 AM
92integra_gs's Avatar
http://www.hondaswap.com/forum...29801
do it yourself... loan the tools from autozone or kragens... or some auto parts store...
Old Jul 21, 2004 | 07:40 AM
Synth124's Avatar
Default Re: (92integra_gs)
I have no air compressor
Old Jul 21, 2004 | 07:41 AM
Synth124's Avatar
Default Re: (Synth124)
BTW BUMP! I need some input since it's my day off and I'll be doing car related work all day long.
Old Jul 21, 2004 | 09:48 AM
LSVTEC 91 Civic's Avatar
Banned
You're worried about coolant in oil? Have you checked oil for traces of coolant?
Old Jul 24, 2004 | 10:42 PM
chevykiller03's Avatar
Default Re: Maybe a stupid question (Synth124)
Is it possible to have too much oil in the car? Hondas do that with too much oil. White smoke, hesitation, choking, no acceleration. Sounds too simple but possible, easy solution also, drain some oil. Just a thought. Not all problems are difficult to fix.
Old Jul 24, 2004 | 10:45 PM
ThatRicerDaniel's Avatar
if its a full rebuild did you correctly prime the motor for a fresh start. hope you did. How many qts of oil did you put it? you need to prime it with 4 qts of non synthetic and run it then I drain that and put in four qts of good oil. to prime the motor you need to turn the car over approx. 8-10 times with out pushing in the clutch.
Old Jul 24, 2004 | 10:53 PM
miskone's Avatar
One time i put too much oil and it started to white smoke. drained and put new oil in and still white smoked. found out that the too much oil fried the spark plugs. replaced those and ran like new. try that if that does not work i don't know. good luck.
Old Jul 24, 2004 | 10:57 PM
Default Re: Maybe a stupid question (miskone)
if he fouls the plugs it will run like a lawn mower.
Clash0901
12
Jun 6, 2010 01:36 PM
tony_yang
May 13, 2010 07:18 AM
hondarondon9296
Oct 11, 2009 12:38 PM
project ak
Jul 28, 2006 03:00 AM
plastik462003
May 24, 2003 10:47 AM
