Overheating 92 Honda Accord...Please Help
Old Jul 20, 2004 | 10:05 PM
kase's Avatar
Default Overheating 92 Honda Accord...Please Help
Hi i have a 92 honda accord EX. I have an overheating problem. Here's what i done so far. I just change the head gasket, new therostat, Flush the Radiator system, new radiator fluids, change the radiator hose, check for leaks (so far no leaks) and change the temp sensor. Does anyone have any idea what might be wrong.... Please help....Thanks
Old Jul 20, 2004 | 10:11 PM
alb_accord's Avatar
did u change the radiator sensor? the one by the thermostat.
u might be loosing compresion on the cooling system. change the radiator cap. it might just be it.
Old Jul 20, 2004 | 10:48 PM
spankey167's Avatar
Default Re: (alb_accord)
Check the water pump? Has it been changed? It might have seized up wont circulate the radiator fluid fast enough.
Old Jul 20, 2004 | 11:34 PM
accordnut's Avatar
Default Re: (spankey167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankey167 &raquo;</TD></TR><TR><TD CLASS="quote">Check the water pump? Has it been changed? It might have seized up wont circulate the radiator fluid fast enough. </TD></TR></TABLE>
Timing belt driven, if it is seized the belt will brake.
Honda therm? Fan works?
Old Jul 20, 2004 | 11:59 PM
spankey167's Avatar
Default Re: (accordnut)
Yea obviously. What i was meaning to say that if the water pump was not running correctly as in slower than usual due to rusting and what not
Old Jul 21, 2004 | 07:18 AM
dockersguy's Avatar
Default Re: Overheating 92 Honda Accord...Please Help (kase)
Was your car fine one day and the next day it overheated? When does your car overheat? I have had a problem with a non-oem thermostat from kragen, is your new thermostat a Honda OEM part?
Old Jul 21, 2004 | 07:54 AM
kase's Avatar
No i didnt thing about changing the radiator sensor. but i will. The car when i start it up, the temp jumps to half right away. then it works itself up slowly, even without driving. How can you tell if the water pump gone bad without it leaking??. And bout the thermostat. it not OEM i got it from AutoZone. I ran the car without the thermostat before to see if that would solve the problem, but it still overheated..
Old Jul 21, 2004 | 08:43 AM
JimBlake's Avatar
Default Re: (kase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kase &raquo;</TD></TR><TR><TD CLASS="quote">The car when i start it up, the temp jumps to half right away. then it works itself up slowly, even without driving.</TD></TR></TABLE>This part sounds suspicious. If the car's been off for hours, completely cold, does the temperature gauge instantly jump to mid-scale? If so, it sounds like your gauge, wiring, or sender is bad.
Old Jul 21, 2004 | 10:02 AM
kase's Avatar
yeah it jump within 20 sec
Old Jul 21, 2004 | 10:13 AM
JimBlake's Avatar
Default Re: (kase)
That's too fast. My suspicions are with a bad temperature measurement.
Bad wiring? Bad gauge? Circuit drawing or a repair book would say how to check.
Might be a bad sender for the gauge, you test that my measuring resistance while heating it in a pot of water (with a thermometer). But you said you already replaced that? Did you replace the sender for the temperature gauge or the sensor for the ECU? In my cars they're not the same sensors.
Old Jul 21, 2004 | 10:26 AM
kase's Avatar
where can i locate the sender for the temperature gauge and the sensor for the ECU
Old Jul 21, 2004 | 10:44 AM
kase's Avatar
Here's something i notice, While im flushing the radiator system. when i put the water hose in the radiator while the engine runs. the temp stays a half, but when i put the radiator hoses and cap back on it heat up.
Old Jul 21, 2004 | 11:37 AM
JimBlake's Avatar
Default Re: (kase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kase &raquo;</TD></TR><TR><TD CLASS="quote">where can i locate the sender for the temperature gauge and the sensor for the ECU</TD></TR></TABLE>Honda moved them around for some different years. In my '95 integra & '98 Accord they're like this...
Radiator fan switch is in the thermostat housing (lower hose). 2-wire plug.
The other 2 are in the head, near the upper hose nozzle:
Temperature sensor for ECU has a 2-wire plug.
Sender for dashboard temperature gauge has only 1 wire.
Old Jul 21, 2004 | 02:32 PM
wyldbil's Avatar
Default SMALL suggestion:
Make sure your overflow cap is screwed on good and tight. True story:
Took my '91 EX wagon in for (you guessed it) overheating. They replaced the thermostat. Still overheating. They did a timing belt and water pump (necessary since I had just bought an almost 200K car with no maintenance records or other provenance- would have done within a couple weeks anyway) Car ran fine for a couple of days UNTIL we took a trip to Atlanta. About halfway there, it starts OVERHEATING.
Turned off the air, opened the windows, turned the heat all the way up and kept going. Stopped every fifty miles or so from then on just on general principle. Checked all fluids every stop to be sure. LAST stop before Atlanta, I discovered the overflow cap was just lying there loose. Screwed it back on tight, and no problems since! That does include a LOT of subsequent driving and a couple of trips. (This was all two months ago...)
The lesson: Replace your radiator cap just on general principle, and make sure your overflow lid is screwed down good and TIGHT!
I love my Accord!
Old Jul 22, 2004 | 09:40 PM
92hondaaccord's Avatar
To check the gauge turn on the car, pull the wire off the unit and ground it. If the gauge reads the max it should be good. The sensor is right below the distributor on my 92 lx.
Let me know if you are still having problems.
Christlike
Nov 8, 2023 09:32 AM
Camato
24
Dec 13, 2016 03:21 AM
jahwarrior1423
Apr 14, 2015 03:01 PM
slartibartfast
Jul 1, 2008 11:10 AM
hOndafienD 04
Nov 5, 2004 05:23 PM
