weird sound from axles?
Old Jul 20, 2004 | 09:24 PM
deviant1's Avatar
Default weird sound from axles?
I replaced my driver side axel and ever since the tranny/axle makes a weird sound when the car starts going from a dead stop. kinda like the splines move a little then engane the other splines in the tranny. my passenger side seems to be doing this now as well but i havent replaced that axle yet even tho the boot has blown. anyone know what this sound could be?
Old Jul 20, 2004 | 09:27 PM
Spade's Avatar
Default Re: weird sound from axles? (deviant1)
Main imput shaft bearing more than likely.
Kind of a whirring sound? Deep and mechanical?
Old Jul 20, 2004 | 09:28 PM
deviant1's Avatar
Default Re: weird sound from axles? (Spade)
not really whirring. just like an engagement sound. like a metal clink.
Old Jul 20, 2004 | 09:29 PM
Spade's Avatar
Did you refill the tranny with fluid? (has to be asked)
Old Jul 20, 2004 | 10:03 PM
Bc1r6x's Avatar
if it olny makes the sound when you are turning it could be the other half shaft
Old Jul 20, 2004 | 11:30 PM
skrewdriver88's Avatar
Default Re: weird sound from axles? (nsxwhitehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">not really whirring. just like an engagement sound. like a metal clink.</TD></TR></TABLE>
I have the same problem and I think it is the bearings inside the axle.
Old Jul 21, 2004 | 12:13 AM
deviant1's Avatar
Default Re: weird sound from axles? (skrewdriver88)
yes, the tranny has fluid in it.
no, its not when turning. when i start rolling from a dead stop, like from a red light.
Old Jul 21, 2004 | 06:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">yes, the tranny has fluid in it.
no, its not when turning. when i start rolling from a dead stop, like from a red light.</TD></TR></TABLE>
Mine does it also but if you go slow from a dead stop it doesn't do it. Is that how yours is?
Old Jul 21, 2004 | 06:30 AM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">
Mine does it also but if you go slow from a dead stop it doesn't do it. Is that how yours is?</TD></TR></TABLE>
Sounds like bad cv joints to me.
Old Jul 21, 2004 | 07:21 AM
I just had my outer CV boots replaced about 6 monthes ago and they said that the inner ones still look good. So is there anything else it could be?
Old Jul 21, 2004 | 03:02 PM
deviant1's Avatar
yup
Old Jul 21, 2004 | 03:10 PM
Frozen E's Avatar
H-T White Ops
mine does that too. I have an EM1. I have a new set of axles from raxles.com sitting here waiting to go in when I get the tirbo in. Hopefully that'll fix the problem.
Old Jul 22, 2004 | 01:36 PM
vtec_hatch's Avatar
i've recently had the same problem too. its possible that the splines are worn and not sitting correctly. reason i'm thinking it's this is because it first clicks when I reverse out of my garage. I can stop, and then reverse again from a stop, but it won't do it again. It will however do it after putting it into first, moving slightly enough to start turning the wheels. Throw it back in and you'll hear the same noise. I'm almost positive its worn splines.
*edit* spelling
Old Jul 22, 2004 | 02:34 PM
Eclpze97's Avatar
Default Re: (vtec_hatch)
yea mine just started doing it within the last week two, i only have 47k on my car, is this bad? what do i have to do to fix it?
EF909
Mar 7, 2011 08:08 AM
ivan93egreppin210
Aug 2, 2009 09:48 PM
Liquidgsr
Feb 26, 2004 11:08 AM
Derek14
Jul 25, 2003 06:33 PM
