dual stage boost controller and p75 LS ecu
any pics for the boost controller? and do u have any vouches,and what is the brand new price for the boost controller pls prove it with evidence
Here's the link for the price:
http://www.turboneonstore.com/boost_controller.htm
This boost controller cost $195 with shipping.
If your interested I can get a moderator to vouch for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky88 »</TD></TR><TR><TD CLASS="quote">this is not an eletronic one right</TD></TR></TABLE>
It is electronic and manual. It is manual in the fact that you need to adjust both the high and low. But electronic in the fact that you hook up a switch to go from high to low boost. I had this unit in my last car that was stolen and loved it. Never had a problem with the unit. A lot less things to break vs an electronic BC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">How do you control fuel enrichment between the two boost settings?</TD></TR></TABLE>
With hondata, uberdata, aem ems, crome, turboedit, etc. For example if your tuned for 14 psi max on hondata you'll be okay up to 14 psi. So you can run 7 psi for your first setting and 14 psi as your second setting.
Yes it would work with the hack. With hondata or any other standalone your different amounts of fuel at 7 psi compared to 14 psi. Obivoulsy your getting more fuel at 14 psi then 7 psi.
rice a roni
Apr 20, 2007 05:56 AM
