Need help with oem tach
Old Jul 20, 2004 | 06:47 PM
myke's Avatar
From: South LA...107th and fig to be exact...for the foo
Default Need help with oem tach
i am using a vx cluster in my eg6 ... but the cluster seem to be off by damn near 2000 rpm. Its seems to be on point tell vtec kicks in then its starts lagging , i guess it cant keep up with the motor. When i dynoed my car the needle on the tach would read about 7200 rpm and the dyno shows 9300 rpm. Is it time for a new cluster? I really dont want to use an aftermarket monster tach i think they look cheesy
Old Jul 20, 2004 | 07:28 PM
akhom's Avatar
Default Re: Need help with oem tach (myke)
I have noticed that 92-95 Civic Tach meter are kinda off.
For example. When in fifth gear going 120 KMH the RPM should be at 4000.
However I have seen it as low as 3000 and have see it as high as 4500 rpm.
While holding a constant 120 KMH the RPM will land anywhere in between.
If I slow down or change gears and go back to 120 KMH the RPM will be a few hundred off from 1 min ago.
So go figure.
Thanks
ANdy
Old Jul 20, 2004 | 07:49 PM
myke's Avatar
Default Re: Need help with oem tach (akhom)
is the jdm cluster tach off too?
offspringpunk14
Sep 8, 2009 05:53 PM
AFAccord
Jan 3, 2006 05:30 AM
outkast_15
Oct 31, 2005 09:58 PM
JDM EG2
Apr 30, 2003 12:17 PM
