Will a K20 fit in 97 Accord??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">Why do k20 when you could buy damn near three H22's and trannys and have money left over. </TD></TR></TABLE>
werd. It's nice that he's trying to be different, but its just not cheap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jazmine »</TD></TR><TR><TD CLASS="quote">Will it fit in 1997 Accord???? And is it worth it???</TD></TR></TABLE>
It would be really expensive to swap in, and why would you swap in a smaller motor?
Here is the rule:
You never, ever, ever, swap a smaller motor into a car than what it came with from the factory.
Here is the rule:
check out this site they've got K20's for 5450.00 which i think is less that 3 times the price of an H22. I say
to the K20 swap, won't be too many around with an rsx engine. http://www.jspecautosports.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Nick M »</TD></TR><TR><TD CLASS="quote">
Here is the rule:
You never, ever, ever, swap a smaller motor into a car than what it came with from the factory.</TD></TR></TABLE>
Why's that? Is it a weight issue? If so, just add some weight to the front end. The k20a4 has more power than the h22, and will be more common in the coming years as the h22 dies out.
Here is the rule:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyrojeff »</TD></TR><TR><TD CLASS="quote">
Why's that? Is it a weight issue? If so, just add some weight to the front end. The k20a4 has more power than the h22, and will be more common in the coming years as the h22 dies out.</TD></TR></TABLE>
usually because a smaller engine produces less torque and if a car came with a bigger engine from the factor, then it prolly had that bigger engine for a reason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K24A4 »</TD></TR><TR><TD CLASS="quote">^^^ yup thats been done on a RSX. and why not get a K24 off the TSX?</TD></TR></TABLE>
The TSX has a K20 and not a K24, which is in the Accord. Someone verify this. Correct me if I'm wrong.
good luck with the uncharted water adventure
I am sure you can, but how well will it run, i dont know.
how much will it cost? how long will it take?
unless slicing harness, cutting and welding is your game, i would strongly sugguest the good ole' h22.
not to mention the source of the motor is expensive, once you break a part, you'll have to get it at premium price. Good luck having it run right.
i think 20 of us already mention why swapping a small motor than the one you have is a bad thing.
if you happen to get it running and not cost a fortune while making some good number, consider yourself the K series boom inventor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAccord96 »</TD></TR><TR><TD CLASS="quote">The TSX has a K20 and not a K24, which is in the Accord. Someone verify this. Correct me if I'm wrong.</TD></TR></TABLE>
im pretty sure you are wrong, K20 in RSX, K24 in TSX and the new accord has a V6 not a I4 so im not sure what code it is. and the TL has a V6 as well and im not sure what that code is too.
The US TSX has a K24A2, the new Accord comes with a K24A4 (as well as a V6).
The K24 is the way to go here, Hasport will be working on a swap kit for the Accords soon. Look for a release around SEMA.
brian g
brian g
Well why would you ever want a smaller motor? Lets ask the opposite question, whats the benefit of a smaller motor?
Nothing.
The k20 does not have more power than an h22a.
The only K worth considering is the K24 from the TSX, or a k24/k20 head combo. Otherwise, you are wasting your money.
Nothing.
Just read the SCC article on this. An '02+ CRV block (K24A1) and Type-S head (K20A2), and the power peaks 20 whp/31 wtq above a stock Type-S, and the gains are at least 10 hp throughout the entire RPM band. The TSX block would produce better gains, but its extremely expensive and rare compared to the K-series CRV engines.
Here's some good info about the engines I pulled outta the mag.
JDM Integra / JDM Civic Type-R (K20A) CR: 11.5:1
Acura RSX Type-S (K20A2) CR: 11.0:1
Acura RSX Base (K20A3) CR: 9.8:1
'02+ Honda Civic Si (K20A3) CR: 9.8:1
'02+ Honda CRV (K24A1) CR: 9.6:1
Acura TSX (K24A2) CR: 10.5:1
Honda Element & '03+ Accord (K24A4) CR: 9.7:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g »</TD></TR><TR><TD CLASS="quote">
brian g</TD></TR></TABLE>
And I know I'm excited. Any pics of the prototype or project Accord?
businessmanph
Jun 27, 2005 09:00 AM
im_the_teacher
Audio / Security / Video
Oct 3, 2003 12:20 PM
