with LSD, the steering knock?
Old Jul 20, 2004 | 04:30 PM
tallblondkid's Avatar
Default with LSD, does the steering knock?
i just swapped my motor w/ lsd, and when i turn the wheel all the way the steering knocks. it only does it when the car is in gear and driving, not when its in neutral or when clutch is in. someone told me this is common with LSDs, but not sure. and if this is true, how bad should the knocking be? any help is appreciate, thanks
Old Jul 20, 2004 | 04:52 PM
S9i1R's Avatar
Default Re: with LSD, does the steering knock? (tallblondkid)
what type of LSD was used? yes it's common, when turning a radius the wheel on the low side of the turn has to travel less than the wheel on the high side of the turn. thats where the 'knocking' comes from, the spider gears on the inside are trying to catch up w/ the spider gears on the outside.
Old Jul 20, 2004 | 05:29 PM
2kgs-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallblondkid &raquo;</TD></TR><TR><TD CLASS="quote">i just swapped my motor w/ lsd, and when i turn the wheel all the way the steering knocks. it only does it when the car is in gear and driving, not when its in neutral or when clutch is in. someone told me this is common with LSDs, but not sure. and if this is true, how bad should the knocking be? any help is appreciate, thanks</TD></TR></TABLE>
Can you explain this knock, I have never heard of knocking of the steering wheel.
Old Jul 20, 2004 | 06:52 PM
krazie1's Avatar
BANNED
Default Re: with LSD, does the steering knock? (2kgs-R)
crazy never heard this
I like to know before getting the KAaay LSd installed
is this only to stock LSD's or aftermarket
and just drive it or be careful about this????
Old Jul 20, 2004 | 07:54 PM
no2psi's Avatar
I have a Kaaz LSD, and yes it is normal. More of a clunking. You can make it more quiet by using 80-90 gear oil with a LSD additive, if you have not allready done so. When I first heard it I was shocked also.
Old Jul 21, 2004 | 07:52 AM
Default Re: (no2psi)
its an aftermarket LSD, i believe kaaz or quaiffe, but some times it feels pretty bad, like i feel like the axles are going to pop out and sometimes even if the wheel is turned half a turn, is this normal?
Old Jul 21, 2004 | 07:54 AM
S9i1R's Avatar
Default Re: (tallblondkid)
did you read the first post it should explain what is going on
Old Jul 21, 2004 | 08:04 AM
Default Re: (S9i1R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S9i1R &raquo;</TD></TR><TR><TD CLASS="quote">did you read the first post it should explain what is going on</TD></TR></TABLE>
yes, but i just wanted to make sure that it being this bad is normal... thanks for your help bro
Old Jul 21, 2004 | 11:54 AM
bump
Old Jul 21, 2004 | 12:20 PM
b16supertuner's Avatar
sounds like Clutch type LSD chatter.
you really need to figure out what type of LSD it is...
if its a quaiffe, it is a gear type LSD, and should never make any noise.
if its a Kaaz, it is a clutch type, and requires special fluid to prevent chatter and damage to the clutch disks inside. Do a search to see how clutch type LSD's work
Kaaz LSDs require fluid with clutch type LSD additive, or Kaaz brand fluid.
-Peter
Old Jul 21, 2004 | 12:30 PM
2kgs-R's Avatar
Default Re: (b16supertuner)
yeah I have a quaife and it makes absolutely no noise what so ever. Also its very smooth when transfering power to the out side wheels.
jdmsleeper12
Transmission & Drivetrain
13
Jan 21, 2010 04:58 PM
C5teg
Dec 21, 2007 01:17 AM
1Quikgsr
Feb 12, 2004 08:11 PM
TypeR 599
Aug 26, 2002 02:10 PM
Soku1kcivic
Apr 16, 2002 04:21 PM
