B18C1 into 96 hatch rewiring help
Im swapping a b18c1 into my 96 civic dx. I have a Ex wire harness. I have everything pretty much wired up except for this plug
I checked back on my ex motor that I had and the plug goes to this plug
So I tried going back to my B18C1 block and plugging it into the one on the B18C1 plug, but they didn't match up... it has a 2-pin connector.
What do I need to do here? How I go about rewiring it to make it work or is there a easier way to make it work? Any help would be nice.
Modified by SivikHatch at 7:54 PM 7/20/2004
Modified by SivikHatch at 7:57 PM 7/20/2004
Modified by SivikHatch at 7:58 PM 7/20/2004
Modified by SivikHatch at 8:01 PM 7/20/2004
I'm not sure if yall get to see the pictures so I'll explain which plug im talking about. On the Ex harness its a 3 pin connector that suppose to plug into a wire that comes out from behind the crank pulley. But on the B18C1, the connector coming from behind the crack pulley has only 2 connectors. Hope this explains my problem a better.
