Best cams for the GSR
The best cams for your motor depend on what mods you have done, and compression. Bigger cams need more compression otherwise you bleed off the compression with the overlap.
are those all the mods you listed? if so, damn, you got one strong *** motor!!
EDIT: oops, i didnt see that he had toda bs. he should definitly be making more power
[Modified by civicnightracer, 7:46 PM 11/25/2001]
well spec B's don't make that much more power than ITR cams. Only after 8000 rpms is when it starts beating it. I'm assuming comptechgsr doesn't have an upgraded ecu to take advantage of a higher redline. dang...if you got 176 with i/h/e and itr cams with tuning, i'd say you have a strong motor too. I've seen alot of gsr's with i/h/e and they only pull about low to mid 150's. Can changing to itr cams with tuning really add 15-20 hp?
my car made 176 whp with i/h/e and ITR cam with tuning. 182 whp with B's ain't impressive. maybe they are not tuned???
all i have for tuning is Plus and minus 2 for cam gears
leaned out idle with vafc by 28percent
vtec x-over @ 6700
i wanna hit high 180s with the Skunk2ITM
and high 190s or higher with an 11.6CR
vtec x-over @ 6700
FastAllmotorLsVtec
Jun 7, 2005 05:12 AM
LaminaRX
Nov 7, 2003 08:15 PM
