door ajar light comes on when brakes pressed
Old Jul 20, 2004 | 01:53 PM
mark_w_martin's Avatar
Default door ajar light comes on when brakes pressed
When I hit the brakes anything but lightly, my door ajar light and chime goes off. Any idea what is causing this? I can't help but think inertia is closing a switch somewhere because if I come to a slow easy stop, it does not happen. Any help would be appreciated.
Old Jul 20, 2004 | 07:43 PM
pyrojeff's Avatar
Default Re: door ajar light comes on when brakes pressed (mark_w_martin)
Wow, thats fucked up. Are you sure nothings getting caught in the door jamb when you're closing the door or something? Because that is really weird.
Old Jul 20, 2004 | 07:46 PM
M2nR's Avatar
Default Re: door ajar light comes on when brakes pressed (pyrojeff)
here just take out the guage cluster and simply disconnect the door ajar light.........problem fixed......i dont really think that that light is of much use anyways
Old Jul 21, 2004 | 08:44 AM
philadd's Avatar
Does it only happen when you are slowing to a stop? Or can you reproduce it by slamming on the brake while not moving? If the latter, you've probably got a short somewhere, and I wouldn't know where to start with that.
If it only happens while coming to a stop, I'd start by checking/replacing the switch to whichever door it thinks is opening.
Old Jul 21, 2004 | 04:58 PM
Schmitey's Avatar
Default Re: door ajar light comes on when brakes pressed (philadd)
Similar thing happened to me on my Eclipse, however that was after my friend backed into me and bent up the door. Check the switch around the door and make sure everything is coshure (sp?). You might also try duct taping a quarter or something to the door to press the switch in further. Who knows, could be something in the latching mechanism I suppose.
Old Jul 21, 2004 | 05:17 PM
HondaFool's Avatar
Default Re: door ajar light comes on when brakes pressed (Schmitey)
Definitely sounds like a short to me. Have you made any recent mods to any lighting or to the gauge cluster? Have you recently been in any form of accident or anything? Struck by lightning (LOL, kidding)?
Old Jul 21, 2004 | 05:23 PM
JAC999's Avatar
Default Re: door ajar light comes on when brakes pressed (HondaFool)
LOL struck by lightning, that’s no good. I would say disconnect it like M2nR22 said. Honestly I can hear when someone doesn’t close the door all the way.
Old Jul 21, 2004 | 05:31 PM
HondaFool's Avatar
Default Re: door ajar light comes on when brakes pressed (JAC999)
Yeah, I suppose you're right, Jac. Most people would know when their door is ajar without a useless warning light. If you wanted to be **** about it, you could always bring your car to a dealer or to a shop to have it checked out...it could even be as simple as a gimped fuse or something.
Old Jul 21, 2004 | 05:34 PM
JAC999's Avatar
LOL and possibly get charged an arm and a leg. Sorry I have bad karma with dealerships. Though I have some buddies that are pretty good with stuff like that. Maybe you could take it to a local shop that works on cars if it is that much of an issue.
Silent_Destruct
Nov 26, 2006 07:02 PM
KraZyCHOWMEIN
Sep 23, 2005 07:22 AM
codyb13
Jan 31, 2005 07:38 PM
powerls
Mar 12, 2004 08:19 AM
Seedc2
Mar 13, 2003 03:24 PM
