Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Zeal B2's vs. OTS/Koni setup
Old Jul 20, 2004 | 10:51 AM
solorex's Avatar
Default Zeal B2's vs. OTS Koni/GC setup
I have recently come across a set of Zeal B2's (used) for a good price. Currently, I run OTS Konis with Neuspeed Race springs. My car is a '91 CRX Si and is my daily driver/solo II car. Would I be better off getting a set of GC sleeves and keeping my Konis? Or should I fork out some dough for the Zeals?
I have had good success locally with my current setup, but I feel I need to start playing with spring rates...
Old Jul 20, 2004 | 10:55 AM
Xian's Avatar
Default Re: Zeal B2's vs. OTS Koni/GC setup (solorex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solorex &raquo;</TD></TR><TR><TD CLASS="quote">I have had good success locally with my current setup, but I feel I need to start playing with spring rates...</TD></TR></TABLE>
hmmmm... maybe just buy new springs and get your Koni's revalved if they aren't up to snuff?
Christian, who thinks you could do a-lot of tuning with what you'd spend on those pimpy Zeals
Old Jul 20, 2004 | 11:15 AM
Team 4's Avatar
Default Re: Zeal B2's vs. OTS Koni/GC setup (Xian)
The B2's are OK, but you'd probably be better getting your Koni's revalved and some stiffer springs.
Old Jul 20, 2004 | 11:48 AM
DB2-R81's Avatar
25 Year Member
Default Re: Zeal B2's vs. OTS Koni/GC setup (REVHARD_EF)
Hello Tyson,
Judging from this past weekend’s performance you need more then new springs and dampers. VCMC is offering a Velocity II school. Hehe! J/K
If the cost is equal for the two spring and damper set ups you are considering I suggest sticking with the Koni's and GC sleeves. Your dampening adjustment range and spring choice will be larger, easer to make changes and service with the Koni/GC set up.
Old Jul 20, 2004 | 11:57 AM
Todd00's Avatar
I said I don't want a title!
B2's = street setup. Valved too soft IMO.
However, you could always send them back for a revalve if you get them cheap enough.
Old Jul 20, 2004 | 01:04 PM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solorex &raquo;</TD></TR><TR><TD CLASS="quote">Currently, I run OTS Konis with Neuspeed Race springs. </TD></TR></TABLE> dang, you need to run some stiffer springs! go G/C !
Old Jul 20, 2004 | 02:08 PM
Mike P.'s Avatar
25 Year Member
A good set of Konis solves every problem.
+1 on the Koni Sports.
Old Jul 21, 2004 | 12:22 PM
solorex's Avatar
Default Re: Zeal B2's vs. OTS Koni/GC setup (DB2-R81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB2-R81 &raquo;</TD></TR><TR><TD CLASS="quote">Hello Tyson,
Judging from this past weekend’s performance you need more then new springs and dampers. VCMC is offering a Velocity II school. Hehe! J/K</TD></TR></TABLE>
Actually, I found out why I was so slow. My slicks were basically dead, too many heat cycles. Last night at the our tuesday night solo series, both fronts corded! So much for the slicks lasting the entire season! I don't know if I will buy used again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If the cost is equal for the two spring and damper set ups you are considering I suggest sticking with the Koni's and GC sleeves. Your dampening adjustment range and spring choice will be larger, easer to make changes and service with the Koni/GC set up.
Looks like my better option is to get some GC sleeves, play with the spring rates until I find what works the best, then get the Koni's revalved accordingly. Sound like a good plan? I appreciated everyone's input. Thanks.
maxogsr
Jan 31, 2009 03:40 AM
99hondacura
Suspension & Brakes
11
Jul 7, 2008 09:13 PM
sohctodohc
Suspension & Brakes
15
May 17, 2006 04:22 PM
The Destroyer
Suspension & Brakes
16
Mar 23, 2005 11:55 AM
AccordVtec
Jan 5, 2003 11:13 AM
