B20 Vtec Upgrade
Old Jul 20, 2004 | 10:33 AM
Mr-Sheep's Avatar
Default B20 Vtec Upgrade
I have a b16a/b20b motor that is starting to smoke when pulling away hard, planning to rebuild it to be stronger. I would like any recomendations from anyone who has done this, esp' on upgrading parts of the rotating assembly.
Old Jul 20, 2004 | 10:54 AM
Propulsion's Avatar
Default Re: B20 Vtec Upgrade (Mr-Sheep)
get new pistons and rods that relocate the wrist pin up to yield better r/s ratio
Keep compression 11 or below if retaining stock sleeves. Make sure you tune it right from the beginning w/ no detonation because the sleeves won't handle any of that.
Old Jul 25, 2004 | 09:55 AM
Mr-Sheep's Avatar
Default Re: B20 Vtec Upgrade (SilverCIVIC96)
ok I've been looking around for sets of rods and pistons. So far from what I've read JE pistons are the way forward, with maybe a set of their h - beam rods? I've seen some kits available that come with the two together with pins and rings. These are all in the states and I'm in the UK so I need to be certail before I shell out all my cash.
Also, is likely that I'll need to rebore the block and go for an 85mm?
Old Jul 25, 2004 | 04:12 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr-Sheep &raquo;</TD></TR><TR><TD CLASS="quote">ok I've been looking around for sets of rods and pistons. So far from what I've read JE pistons are the way forward, with maybe a set of their h - beam rods? I've seen some kits available that come with the two together with pins and rings. These are all in the states and I'm in the UK so I need to be certail before I shell out all my cash.
Also, is likely that I'll need to rebore the block and go for an 85mm?</TD></TR></TABLE>
the most you'll need to bore is .002" you wont need to go an entire millimeter. this is only if the walls have scars on them. I suggest you take your motor apart and find out what parts you need prior to ordering them.
Old Jul 25, 2004 | 05:04 PM
chad's Avatar
Moderator
Default Re: B20 Vtec Upgrade (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">
the most you'll need to bore is .002" you wont need to go an entire millimeter. this is only if the walls have scars on them. I suggest you take your motor apart and find out what parts you need prior to ordering them.</TD></TR></TABLE>
if he goes aftermarket pistons he will have to go .5 mm overbore.....if he goes stock oversized pistons he can go .25 mm over.....
.002 inches isn't very much.....
ribal_gh
11
Jan 17, 2013 11:10 AM
Ewing8712
Dec 21, 2009 08:51 AM
QB21
Dec 17, 2005 11:24 AM
benzcivic99
Jun 21, 2002 11:27 PM
