ITR Springs - longer springs in the rear?
Old Jul 20, 2004 | 09:21 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default ITR Springs
I just bought a set of used ITR springs?
Pics: (Thanks ebelp)
Do the longer springs go in the front or the rear? Thanks!
Old Jul 20, 2004 | 10:28 AM
jdmspoonitr's Avatar
Default Re: ITR Springs (FrostyDC4)
Is it me or do those springs look too thin to be itr springs.
Old Jul 20, 2004 | 10:29 AM
.RJ's Avatar
.RJ
Default Re: ITR Springs (jdmspoonitr)
The markings are correct, and the longer springs go in the rear. You'll need a spring compressor for the fronts.
Old Jul 20, 2004 | 10:35 AM
Hooch'n's Avatar
Default Re: ITR Springs (.RJ)
wow, what r the spring rates for Stock Springs?
Me used to 650 and 800!
Old Jul 20, 2004 | 12:06 PM
M12's Avatar
M12
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">The markings are correct, and the longer springs go in the rear. You'll need a spring compressor for the fronts.</TD></TR></TABLE>
I think its the other way around.
Longer springs up front.
Old Jul 20, 2004 | 12:07 PM
RTW DC2R's Avatar
Default Re: ITR Springs (M12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M12 &raquo;</TD></TR><TR><TD CLASS="quote">
Longer springs up front. </TD></TR></TABLE>
this is what I was thinking as well. been so long since I swapped out the springs though.
Old Jul 20, 2004 | 12:12 PM
.RJ's Avatar
.RJ
Default Re: ITR Springs (RTW DC2)
Hrm, I think you guys are right.
Old Jul 21, 2004 | 06:34 PM
Girl's Avatar
So long springs in front, short springs in back? It doesn't matter what side does it? Cuz I just got a set myself... and I need to put them in.
Old Jul 21, 2004 | 06:43 PM
98itr0448's Avatar
You might find that one of the two springs should fit better on either the front or rear struts. Other than that, my vote is long springs in front, short in back.
Old Jul 21, 2004 | 06:49 PM
obd2gsr's Avatar
Default Re: ITR Springs (98Itr-0448)
spring rates are 250/250
Old Jul 21, 2004 | 06:54 PM
kkim's Avatar
Default Re: ITR Springs (obd2gsr)
use the pic to determine which of your springs match the ones in the picture. Shocks w/o the eyes on the bottom are the fronts.
Old Jul 21, 2004 | 06:57 PM
Girl's Avatar
So that means the long ones in front, and short ones in back... Thanks.
Old Jul 21, 2004 | 09:01 PM
IN VTEC's Avatar
Default Re: (Girl)
Yup. Only the rear springs have the rubber on them if you had to use just one characteristic to decide.
Old Jul 22, 2004 | 10:16 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Yup. Only the rear springs have the rubber on them if you had to use just one characteristic to decide.</TD></TR></TABLE>
Ah I see.
Thanks
Old Jul 22, 2004 | 10:19 AM
.RJ's Avatar
.RJ
Default Re: ITR Springs (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">use the pic to determine which of your springs match the ones in the picture. Shocks w/o the eyes on the bottom are the fronts.</TD></TR></TABLE>
Those look entirely too clean
Old Jul 22, 2004 | 10:52 PM
Slow_Em1's Avatar
longer in the rear my friend
Old Jul 23, 2004 | 01:04 AM
1993sir00's Avatar
Default Re: ITR Springs (Slow_Em1)
why would you buy used factory type r springs, what sense would that make. cuz the are itr? clue me in please?????????
Old Jul 23, 2004 | 03:56 AM
ebelp's Avatar
Default Re: ITR Springs (1993sir00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir00 &raquo;</TD></TR><TR><TD CLASS="quote">why would you buy used factory type r springs, what sense would that make. cuz the are itr? clue me in please?????????</TD></TR></TABLE>
Some gsr/ls/gs owners like to run them. They are stiffer and will sit you about 1" lower than stock. Just a subtle suspension mod for those folks.
Old Jul 23, 2004 | 06:23 AM
IN VTEC's Avatar
I use them during the winter when I don't want to gunk up my nice coilovers. Some lucky people don't have to worry about snow and road salt.
Old Jul 23, 2004 | 08:04 AM
99IntegraGS's Avatar
Default Re: ITR Springs (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Some gsr/ls/gs owners like to run them. They are stiffer and will sit you about 1" lower than stock. Just a subtle suspension mod for those folks.</TD></TR></TABLE>
I recently swapped my '99 GS springs/shocks for an ITR setup. I didn't get much lowering from it, but the ride is much improved. I don't know why, just know that it's much tighter. Adding a USDM ITR (22mm?) rear sway bar this weekend.
Old Jul 23, 2004 | 08:49 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: ITR Springs (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I use them during the winter when I don't want to gunk up my nice coilovers. Some lucky people don't have to worry about snow and road salt.</TD></TR></TABLE>
Same here.
Old Jul 23, 2004 | 09:51 AM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostyDC4 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a set of used ITR springs?
Do the longer springs go in the front or the rear? Thanks!</TD></TR></TABLE>
Juss remember when looking at the longer set on the left...the FLAT part right at the top of the spring (in the picture it is at the bottom) means front....Round set on the right means rear.
FLAT = front
ROUND = rear
I use ITR springs on my EK hatch and it rides awesome in combination with fresh SiR dampers.
Very subtle lowering too!
Old Jul 23, 2004 | 09:34 PM
Girl's Avatar
I bought some for my car cuz I got my car used and it came with Ground Control Coilovers... And I'd rather be riding with stock ITR Springs.
Old Jul 26, 2004 | 03:39 AM
an2ny888's Avatar
Default Re: (Girl)
fyi, the JDM ITR springs appear to be shorter than the USDM ones. i counted 9 coils on the jdm, as opposed to 10 for the usdm. spring rates should be slightly stiffer also
BlueRex1020
Feb 9, 2007 04:43 PM
b18c inside
Suspension & Brakes
10
Mar 20, 2006 10:14 PM
Wazup
Suspension & Brakes
Feb 6, 2006 10:46 PM
bo0sted
May 28, 2004 01:45 PM
NINJASPY
Jan 16, 2004 10:46 AM
