94 D16 compression test w/140K
Old Jul 20, 2004 | 08:13 AM
SlowGreenEJ's Avatar
Default 94 D16 compression test w/140K
Decided to do a compression test on my 94 EX. It has 140k on it and it runs well, doesn't burn any oil either. I was expecting either low numbers across the board or one or two cylinders to be lower than the rest. So I said what the hell. I may be keeping this motor for a while to boost it or swap a different motor in, but nevertheless wanted to see how she is.
Started with the car being warm, removed the ecu fuse and removed all the plugs. I had one of my buddies watch the gauge while I held the gas down and cranked her four times for each cylinder. I pulled 160 +- two to three psi across the board. I was pretty happy with the results. Now only if I could sell the WRX and get the money to start my project.
How does these numbers sound? Thanks for lookin!
Jon
Old Jul 20, 2004 | 11:53 AM
Tomek's Avatar
Default Re: 94 D16 compression test w/140K (redrex02)
numbers are great. The consistency is key.
Old Jul 20, 2004 | 12:33 PM
ScottFern's Avatar
Default Re: 94 D16 compression test w/140K (Tomek)
Pretty much she is ready for boost. Wasn't 94 the year the d16 came with forged pistons
Old Jul 20, 2004 | 12:36 PM
Soccerking3000's Avatar
Default Re: 94 D16 compression test w/140K (ScottFern)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottFern &raquo;</TD></TR><TR><TD CLASS="quote">Pretty much she is ready for boost. Wasn't 94 the year the d16 came with forged pistons </TD></TR></TABLE>
y yes it did, they can handle 3542636 whp
Old Jul 22, 2004 | 08:44 AM
Default Re: 94 D16 compression test w/140K (Soccerking3000)
Sweet
Old Jul 22, 2004 | 10:23 AM
blackeg's Avatar
my z6 gave me exactly 210 across all 4. now granted this is a little on the high side, and i cranked my motor over 6 or 7 times. 160 for 4 cranks while being very consistent has BOOST ME!!! written all over it
Old Jul 22, 2004 | 10:33 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrex02 &raquo;</TD></TR><TR><TD CLASS="quote">Decided to do a compression test on my 94 EX. It has 140k on it and it runs well, doesn't burn any oil either. I was expecting either low numbers across the board or one or two cylinders to be lower than the rest. So I said what the hell. I may be keeping this motor for a while to boost it or swap a different motor in, but nevertheless wanted to see how she is.
Jon</TD></TR></TABLE>
With that many miles, you should be happy.
This is a fully built Z6. I about had a heart attack. We think the numbers are so high because at the time of the test it had oil in the top of the cylinders (&lt;8 miles) because nothing had seated yet. Still thought I would share.
In order from #1-#4. Also, Number 1 read like the others on a second try. We did it again since the number was lower but it got better (270)
Cyl #1
Cyl #2
Cyl #3
Cyl#4
Old Jul 22, 2004 | 10:37 AM
menkio's Avatar
Default Re: 94 D16 compression test w/140K (ladysman)
jesus thats high..
Deemeetree's Avatar
Electrician
What are good numbers to live by? A good range of numbers that tells you that everything is pretty top knotch in your motor?
Old Jul 22, 2004 | 10:59 AM
BauleyCivic's Avatar
Risky Business
Default Re: (Dimi)
My bud had a picture of a snap on compression gauge going well past the 300 mark on his 13:1 LS/VTEC...i'll see if I can dig it up.
Old Jul 22, 2004 | 11:03 AM
WAFFLES's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">What are good numbers to live by? A good range of numbers that tells you that everything is pretty top knotch in your motor?</TD></TR></TABLE>
The range between the numbers is more important. Normally no more than 20% between cylinders.
Old Jul 23, 2004 | 02:56 PM
Default Re: 94 D16 compression test w/140K (blackeg)
Yea if I cranked it more than 4 times, it shot up. I tried 5 times and it shot up to 175, so i am sure if I cranked it 6 or 7 times I would have seen close to your numbers. oh well, I have always heard there is no need to crank it over 4 times. So yea now I have to decide if im gonna boost up to 10 psi stock block tuned or build up the bottom end and go up to maybe 13 psi tuned. I think I will be very happy with 10 psi tuned.
I was going to go with a swap but having a motor in this good of condition, I don't want to give this motor away. I don't see the point in buying a B18c or H22 swap if I can boost a healthy D series motor. If it was in poor condition, then I would definitely consider getting a swap. Any other opinions would be greatly appreciated, good or bad. Thanks
Jon
Old Jul 23, 2004 | 03:03 PM
electronb16si's Avatar
Sell the WRX to start the project?? Why not sell the civic and put a little cash into a reliable 4 wheel drive 4 door boosted car? I mean I love hondas as much as the next guy here but I think the WRX would be REAL fun with 2-3k put into it. just my .02 but good luck with the turbo!!!
Old Jul 23, 2004 | 04:33 PM
phobi9's Avatar
Default Re: (electronb16si)
I don't think 2-3k would be enough to do jack to a WRX lol
Old Jul 23, 2004 | 05:32 PM
mc's Avatar
mc
Default Re: (phobi9)
while we're on the subject of compression is it ok if the reading on the gauge drops after cranking the motor or should it hold?
Old Jul 23, 2004 | 10:54 PM
Jimmy's Avatar
Global Moderator
I wouldn't run a alot of boost with compression results not perfect..
Goodluck
Old Jul 24, 2004 | 12:13 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (mc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mc &raquo;</TD></TR><TR><TD CLASS="quote">while we're on the subject of compression is it ok if the reading on the gauge drops after cranking the motor or should it hold?</TD></TR></TABLE>
conserning the hold of pressure after the stoke has been cycled is useless info.
what you want to know is what happen at the time of stroke. after that is history. besides, if you had a leak, it would be your gauge's.. not the engine. (valves opeing)
if you've ever wondered how compresion testers work.. imagine a tire. it has a valve stem. air only goes in, doens't come out. so imagine using that concept backwards, and putting a line, and a gauge on the end of it? its the same thing, air only goes in (compresson) and nothing comes back. thats all you want to know.
Old Jul 24, 2004 | 09:52 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrex02 &raquo;</TD></TR><TR><TD CLASS="quote">Yea if I cranked it more than 4 times, it shot up. I tried 5 times and it shot up to 175, so i am sure if I cranked it 6 or 7 times I would have seen close to your numbers. oh well, I have always heard there is no need to crank it over 4 times. So yea now I have to decide if im gonna boost up to 10 psi stock block tuned or build up the bottom end and go up to maybe 13 psi tuned. I think I will be very happy with 10 psi tuned.
**** man i was pretty happy with 6 psi untuned. 10 tuned will be sweet
Old Jul 24, 2004 | 10:10 AM
Yea the wrx would be fun but it is much more expensive, anyway that is personal business anyway. If had had alot of money, you can bet your *** I would keep the scooby. We will see what happens with this lil civic project.
Old Jul 24, 2004 | 10:17 AM
D-Unit's Avatar
Default Re: (BauleyCivic)
Numbers look fine with engine with that many miles
Old Jul 25, 2004 | 06:49 PM
sohcfreak's Avatar
Default Re: (D-Unit)
good
Old Jul 25, 2004 | 07:01 PM
Turbogixxer's Avatar
Default Re: (Dimi)
They say 110-130 is rebuild time (stock motor/compression ratio), but it is (like others said) more about the range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">My bud had a picture of a snap on compression gauge going well past the 300 mark on his 13:1 LS/VTEC...i'll see if I can dig it up.</TD></TR></TABLE>
We did a compression test on my friends Real street motor (V8, all motor). 13.1 is nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't run a alot of boost with compression results not perfect..
Explain, besides the miles. Why would it be bad?
Old Jul 25, 2004 | 07:56 PM
CivicVX94's Avatar
so if this is true, why do so many people drop 350+ bucks on some forged pistons??? are they just forged better?(no clue if that is possible) or is it so you can decide on what comp. you want? Can they handle as much boost as main brand forged pistons???with some nice rods too I mean...
Old Jul 25, 2004 | 07:59 PM
hatchback19's Avatar
Default Re: 94 D16 compression test w/140K (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">
so if this is true, why do so many people drop 350+ bucks on some forged pistons??? are they just forged better?(no clue if that is possible) or is it so you can decide on what comp. you want? Can they handle as much boost as main brand forged pistons???with some nice rods too I mean...</TD></TR></TABLE>
He was joking, they didn't really.
Old Jul 25, 2004 | 08:04 PM
CivicVX94's Avatar
Default Re: 94 D16 compression test w/140K (hatchback19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback19 &raquo;</TD></TR><TR><TD CLASS="quote">
He was joking, they didn't really.</TD></TR></TABLE>
lol no ****? i can never tell if people are joking or not on the internet. I thought it was just a random fact lol
Luserkid
20
Jun 4, 2004 07:50 AM
Eluzion
Dec 21, 2002 12:19 PM
badcabala
Mar 23, 2002 02:04 PM
93LSivic
Oct 2, 2001 06:36 PM
b18bvudoo
Aug 8, 2001 09:52 PM
