Do you guys use the tappet and special wrench for valve adjustments?
you have to get it from snap on or mac, its is pretty expensive if i recall..wrench and screwdriver always worked for me
yes i do,
but there are times were i had to adjust the valve with out them,
adjust it loose, then try to tighten the lock nut by hand without moving the adjuster, then snug them with a 10mm socket. the adjuster will move, but since you adjust them loose, it should be ok. recheck the clearance
but still i recomend you use the special tool, makes like easier and faster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 »</TD></TR><TR><TD CLASS="quote">
its the best 50 you can spend. makes things so much easiler. make money be renting it out haha
</TD></TR></TABLE>its the best 50 you can spend. makes things so much easiler. make money be renting it out haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8sirg »</TD></TR><TR><TD CLASS="quote">
its the best 50 you can spend. makes things so much easiler.</TD></TR></TABLE>
Amen!
Amen!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">
$50 is kind of steep for a tool thats only used once every 30K miles under severe conditions. What brand is that one?</TD></TR></TABLE>
And yet other people won't bat an eye at $200. aluminum jacks, or $900. headers and exhausts, or $500. 17" blingerZoRz.
Get the correct tool the for the job.
$50. is pocket change in the grand scheme of things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">$50 is kind of steep for a tool thats only used once every 30K miles under severe conditions. What brand is that one?</TD></TR></TABLE>
30K? I do mine more often... either way its worth it to have the correct tool.
http://buy1.snapon.com/catalog...talog
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX »</TD></TR><TR><TD CLASS="quote">you have to get it from snap on or mac, its is pretty expensive if i recall..wrench and screwdriver always worked for me</TD></TR></TABLE>
same here
same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet »</TD></TR><TR><TD CLASS="quote">yes i do,
but still i recomend you use the special tool, makes like easier and faster</TD></TR></TABLE>
This works too, but it takes time. It is much much faster with the snap-on locknut adjustment tool
Well worth the $$ IMO
its a matco.
steep? but people have NO problem paying 45 for some drain plugs.
and if you like to rev you need to check your valve more often then 30k.
its a matco.
that Snap on one is awesome once you get used to it.
i need to get one bad. i have used it at a friends shop last time i did mine and it was very nice.
