headlights not working.....did search
I searched for a few things and checked out the fuses on my gsr..still no luck. Well today while driving i noticed my front headlights both werent working so when i stopped i decided to check the fuses...both interior and under the hood and it all seemed to be ok. Is there maybe something i missed or could the wiring have shorted out being that they both wouldnt work? Any input thanks alot
Did your turn signals work? Maybe it's just a fluke that both headlights burned out. Check to make sure the actual bulbs are good.
turn signals work fine....checked both bulbs...the filament is still attached however they both look a little distorted...never really looked at them before. Going tommorow to get new lights...if they dont work...how much should I be looking at if I do need new wires
I think I might know your problem. I had the same problem with my Integra. My left headlight went out but the fuse was fine. There probably is a connection problem. You might want to check where the bulb connects to the main connector. If your car is still under warranty take it to an Acura dealer. They fixed mine for free. Good luck I hope it won't cost you too much if it does.
hey..i have the same problem with my 91 integra...somehow the left driving light is out...but the right one works...both high beams work...it's frustrating me because i checked all the fuses and all were good...and still the low beam on the driver side doesn't work. ( low beam and high beam uses the same bulb ) i don't know what else i can try doing.
any suggestions? help me out too guys. i can't drive my car at night because of that blind low beam on the driver side...and i also can't drive with my high beams on at all times...
Funny you should mention it i got pulled over and got a ticket tonight. Coming out of a well lit parking lot i got pulled over right after i turned onto the road and realized my lights were out.
Check the connection and the bulbs for one. Are the plugs in good shape? When did you change the bulbs. The simplest answer is usually the correct one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaedreamah »</TD></TR><TR><TD CLASS="quote">high beams work..( low beam and high beam uses the same bulb ) i don't know what else i can try doing.</TD></TR></TABLE>
Dual filament bulb. One is probably burned out. Just change your bulbs.
alright well i just got new bulbs from acura and its working fine. It just made me wonder why both went out at the same time. o well i guess
