OBD1 ECU's
Old Nov 25, 2001 | 01:17 AM
Tommy_Gunns's Avatar
Default OBD1 ECU's
I was looking at an OBD1 ECU out of a friends car the other day and I have a few questions. Do all OBD1 ECU's have a removable chip (ie. the one I looked at had a chip slot so you could easily change your ecu chip)? Anybody here running OBD1 ECU's in their ITR? Where can I get an OBD2 to OBD1 wiring harness?
Thanks.
Old Nov 25, 2001 | 02:14 PM
RJL's Avatar
RJL
New User
Default Re: OBD1 ECU's (Tommy_Gunns)
Skunk2 makes a obd2-obd1 harness, a bit pricey i think there around 250.00
Old Nov 25, 2001 | 02:25 PM
kenji's Avatar
25 Year Member
Default Re: OBD1 ECU's (Badboy01GSR)
I make OBD2 to OBD1 ECU conversion harnesses also.
I don't want to mention prices on this board but I am cheaper than Skunk2 and I gaurantee my work.
Email me at kenji211@gte.net if you have any questions.
-kenji
Old Nov 25, 2001 | 03:39 PM
Rboosted717's Avatar
I have a OBD1 ECU in my car. I'm using a P28 ECU with a custom chipping setup, not Hondata. No, OBD1 ECU's do not have removable chips. That socket you saw was put in by the shop who chipped the ECU. When you get a stock p28, p72, etc... ECU you go to the shop who will chip it and they first remove the stock chip or chips that will be replaced with the new ones. They then will install a socket to put the new chip on. Socketing is normally not standard for some shops. Most times they will just install the new chip into the ECU like how the stock one was attached. However you can normally pay an extra charge and they will put a socket in, so that you can swap chips easily.
As for a harness, Skunk has one and so does Kenji. Me personally, I'm using Kenji's and it works great!
Old Nov 25, 2001 | 05:02 PM
norice's Avatar
Default Re: OBD1 ECU's (Rboosted717)
Are there any other sources for these harnesses? $250 seems like a lot for what sounds like a $50 piece of hardware. Perhaps I am wrong, but I don't think that these harnesses contain any electronics - they are simply pin rerouters. (Though, I guess they may be low volume items that involve a lot of labour.)
Old Nov 25, 2001 | 05:40 PM
Default Re: OBD1 ECU's (norice)
I agree, that is alot for just a harness.
swordofdoom
Engine Management and Tuning
19
Jul 27, 2020 08:05 PM
Jason703Racing
Feb 20, 2006 08:52 PM
kennyvb
Aug 25, 2004 02:19 PM
Type R
Jun 18, 2001 12:38 AM
