engine won't turn over help
Having trouble starting motor. Sypmtoms.
-set up
92 si hatch
00 d16y7 motor
engine turns over, and the spark is there at the dizzy. Not at the plugs. Could be wires.
I reused the injectors, intake mani, exhust mani, alternator, and harness.
does anyone know what could be the problem? or has anyone encountered a problem like this and knows any insite as to why its not working properly?
share your info thanks in advance.
-set up
92 si hatch
00 d16y7 motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">Change your wires and see if that's the remedy to your problem. </TD></TR></TABLE>
alright, i'll check wires tomorrow. what is the procedure to aligning a dizzy correctly.
Isn't it brink crank to top dead center, align cam with markings on it and then just stick it on the cam? let me know if there is any other trick or if that could possably be a problem with ingition?
E-Rok
Jul 31, 2003 08:19 AM
