Question about bad rings...
when u have bad rings, will a compression test tell u? or do u have to do a leak down test? also, say u had a motor with bad rings, is it possible to have all 4 cylinders with bad rings?
i mean, i tested my lsvtec and got really low numbers... especially since its supposed to have 11.6:1 compression or so..... all 4 cylinders were extremely low, but with +/- 5!!!!!!!
WTF....
is my tester bad? or did it go all the way around once (only goes to 250) and then some?
how could i have burned all the rings so damn evenly?!
WTF....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridlsR »</TD></TR><TR><TD CLASS="quote">its possible. i had usdm ir pistons in my ls/vtec with bad rings and all cylinders were low.my rings actually never seated properly. </TD></TR></TABLE>
what were your numbers?
Here's a good way to test your rings. Do a first test, write your numbers down. With an oil can, put some oil in the spark plug holes, enough to just coat the rings. If the compression goes up quite a bit, you have blow-by, which means you need new rings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyr0ch »</TD></TR><TR><TD CLASS="quote">Here's a good way to test your rings. Do a first test, write your numbers down. With an oil can, put some oil in the spark plug holes, enough to just coat the rings. If the compression goes up quite a bit, you have blow-by, which means you need new rings.</TD></TR></TABLE>
Yes, very good advice right there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">ok, when i did it, it wasnt at wide open throttle... is that a huge factor? i sorta forgot this part... </TD></TR></TABLE>
It should be done at WOT. But incidentally, my numbers didn't change either way I did it. Do it again at WOT.
