**Chainging Fuel Filter**
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">Make sure you use a Line Wrench aka Flare Nut Wrench.</TD></TR></TABLE>
Correct. Also as a precaution, make sure to disconnect the negative terminal on your battery.
Gas cap won't do ****. Pull the fuel pump fuse and then start the car. The car will stall out when all the residual pressure in the fuel system is gone.
RA12825
Jan 29, 2007 08:51 PM
vietintegboi
Oct 19, 2006 07:33 AM
