?????crower valve train???
Old Jul 19, 2004 | 05:00 PM
h22 civic's Avatar
Default ?????crower valve train???
anybody ever have problems with the titanium retainer or valve springs from crower? specifically on h22
Old Jul 20, 2004 | 12:42 PM
h22 civic's Avatar
Default Re: ?????crower valve train??? (h22 civic)
Old Jul 23, 2004 | 12:38 PM
h22 civic's Avatar
Old Jul 23, 2004 | 01:06 PM
builthatch's Avatar
MiG-21 superfan
Well, I've run my crower springs/ Ti retainers on my y8 for approx. 2 years with no issues...retainer wear is not existent, which most likely has to do with their proprietary Titanium compound that is way resistant to wear vs. other out there...
Old Jul 25, 2004 | 10:46 PM
Garcia-Racing's Avatar
Spring pressure goes away.
Old Jul 26, 2004 | 12:44 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (TGARCIARACING)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TGARCIARACING &raquo;</TD></TR><TR><TD CLASS="quote">Spring pressure goes away.</TD></TR></TABLE>
Are you claiming this in regards to Crower springs or high tension valve springs in general? Either way, what type of conditions did you see this occur (motor setup/ frequency of use/ type of use) and also, what sort of time frame? What type of rate loss did you see?
Old Jul 26, 2004 | 01:41 PM
h22 civic's Avatar
Default Re: (builthatch)
any probs with valves sliping through the retainers ?
Old Jul 26, 2004 | 04:55 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (h22 civic)
not that ive seen with b's and d's...not seen any h's tho---
why, did something happen to yours?
Old Jul 26, 2004 | 05:02 PM
h22 civic's Avatar
not mine but i seen 2 other h"s have problems i was told by dave of head games to use keepers and i should be allright
Old Jul 26, 2004 | 07:11 PM
Crower spring pressure dropped after probably 12 dyno pulls and 7 hard passes. I was going to have oversized valves installed, so I had them tested. They were way too soft. I don't recall exact #'s offhand, but I think I have it written down somewhere. I switched to supertech now.
Turboed b16
Old Jul 27, 2004 | 05:42 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">not mine but i seen 2 other h"s have problems i was told by dave of head games to use keepers and i should be allright </TD></TR></TABLE>
Dave said to use isky keepers as opposed to stock or something, right?
Old Jul 27, 2004 | 05:43 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TGARCIARACING &raquo;</TD></TR><TR><TD CLASS="quote">Crower spring pressure dropped after probably 12 dyno pulls and 7 hard passes. I was going to have oversized valves installed, so I had them tested. They were way too soft. I don't recall exact #'s offhand, but I think I have it written down somewhere. I switched to supertech now.
Turboed b16</TD></TR></TABLE>
i c...i imagine you needed a double spring set, is that what your supertech is?
Old Jul 27, 2004 | 05:54 AM
the crowers were dual valve spring sets, too. #68186
Old Jul 27, 2004 | 07:18 AM
builthatch's Avatar
MiG-21 superfan
How much HP were you making? Just curious, since Crower 68186 is a lower pressure spring set made by Eibach that I am extremely familiar with under the Eibach EVS part number 20401.216; that kit is meant for much milder apps than the high pressure Crower 68188 kit-
Old Jul 27, 2004 | 01:40 PM
h22 civic's Avatar
dosent crower make 2 sets of spring 1 from eibach and 1 from crower?
Old Jul 27, 2004 | 03:56 PM
427 whp b16 turbo @16 psi
Old Jul 27, 2004 | 04:44 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TGARCIARACING &raquo;</TD></TR><TR><TD CLASS="quote">427 whp b16 turbo @16 psi</TD></TR></TABLE>ok yeah, 68186 is the wrong set (obviously : ) for that caliber of setup...68188 is what a setup like that would call for...
nice numbers BTW
Old Jul 27, 2004 | 08:57 PM
Thanks. I was still running stock valves, so I didn't want a spring with that much pressure(like the 68188). I thought the 68186 to be a happy medium. 425 whp was the goal, not too extreme. I've looked for the paper that the #'s were recorded on but I can't find it anywhere; but the seat pressure had dropped a lot. they were definitely not safe for the new setup, which will hopefully make 600+.
Old Jul 29, 2004 | 04:39 PM
h22 civic's Avatar
84167?
Old Jul 29, 2004 | 07:15 PM
builthatch's Avatar
MiG-21 superfan
the opposite seems to be true for the h22 offerings from crower- the eibach set is of a higher rate than the regular issue crower set...
Diggie
K Series
Apr 28, 2019 02:07 PM
State.of.Prime
Oct 17, 2010 01:43 PM
civic00sir.
Mar 19, 2010 09:59 AM
mkw1
Mar 8, 2008 04:43 PM
Amped
Aug 30, 2006 04:33 PM
