will gsr acl bearings fit in b18b block
Old Jul 19, 2004 | 03:21 PM
96tegls's Avatar
Default will gsr acl bearings fit in b18b block
will this work i have a set need to know asap
Old Jul 19, 2004 | 03:25 PM
X-Mazda 3 Racer's Avatar
Default Re: will gsr acl bearings fit in b18b block (96tegls)
The GSR ( B18C ) main and thrust bearings are the same as the B18A/B. The rod bearings are different!!!! If you need rod bearings for LS, they are ACL part # 4B1946 and we have some in stock.
Type R #462's Avatar
67.124.36.228
no it will not work. either the mains are the same and the rods are different or the rods are same and the mains are different. one or the other but the bottom line is that dont put them in your LS motor
Old Jul 19, 2004 | 06:49 PM
zensoku207's Avatar
yes, they will work.
all b18 cranks have the same main bearing size.
Old Jul 19, 2004 | 07:38 PM
StyleTEG's Avatar
Default Re: (Type R #462)
The rods bearings can be made to fit with some slight notching.
Old Jul 19, 2004 | 08:54 PM
Default Re: (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">The rods bearings can be made to fit with some slight notching.</TD></TR></TABLE>
This is not recommended because the B18a/b rod bearing is a little wider than the GSR ( B18C )rod bearing!
Old Jul 19, 2004 | 09:27 PM
StyleTEG's Avatar
Default Re: (GoldenEagleMfg.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote">This is not recommended because the B18a/b rod bearing is a little wider than the GSR ( B18C )rod bearing!</TD></TR></TABLE>
If you were using custom rods would it not be beneficial? (thinking longer rods, with a raised wrist pin or deck plate)
Old Jul 19, 2004 | 11:13 PM
KTeller8's Avatar
Default Re: will gsr acl bearings fit in b18b block (GoldenEagleMfg.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote">The GSR ( B18C ) main and thrust bearings are the same as the B18A/B. The rod bearings are different!!!! If you need rod bearings for LS, they are ACL part # 4B1946 and we have some in stock. </TD></TR></TABLE>
thats is correct. well sell them and thats' exactly what you need
Old Mar 18, 2022 | 04:39 PM
amad perez's Avatar
Something similar to this but will b18b1 rod bearings fit aftermarket rods? Both having standard specs.
Old Mar 18, 2022 | 08:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
As long as the aftermarket rods are for a B18B crankshaft, yes... the rod bearings will fit. They will NOT fit a GSR/ITR crankshaft rod journal.
m88ulrich
Engine Machining & Assembly
Mar 30, 2018 08:39 PM
jarvis199
Dec 11, 2007 12:42 PM
turbo boost
Jan 23, 2007 05:19 PM
amazinspiderman
11
May 16, 2006 06:31 PM
NorthernXposure
Jan 23, 2006 03:40 PM
