What type of mounts should be used for b-series in an EF?
Are there any stock mounts that can be used in this situation or does it have to be aftermarket?
Also how many mount points are there in an ef for a b-series?
I'm not completely sure on this but I've heard of 92-95 EG and 90-93 DA mounts being used on B series. You do have to use the 90-93 Rear mount if you are going B series. That's a must
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenEF9 »</TD></TR><TR><TD CLASS="quote">Are there any stock mounts that can be used in this situation or does it have to be aftermarket?
Also how many mount points are there in an ef for a b-series?</TD></TR></TABLE>
Has to be aftermarket (Place Racing, Hasport, AN-R, Arizona Racing, etc.)
Drivers side mount, transmission mount, rear motor mount (90-93 Teg bracket), and some people retain the front crossmember mount, but its not a must
So 3 mostly
So 3 mostly
You can use stock mounts if you cut and weld your current mounting points to match those from Civic/Crx SiR. Otherwise, you will need an aftermarket mount kit. It is possible to use stock mounts with some modifications. However, the motor may not fit correctly and may lead to other problems. Many of the aftermarket mount kits have been optimized for proper axle angle and overall fit and are worth the money they cost. I believe the stock jdm ef has 4 mount points for the b16a.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyn0speed »</TD></TR><TR><TD CLASS="quote">i recomend hasport. i have em and it feels great and looks good</TD></TR></TABLE>
Is it safe with only three mounts holding up the motor? I thought there should be 5 mounts... two on sides. one in rear and two in the front no?
u get wat u paid for i guess
very safe....there are 4 motor mounts on ur stock motor but hasport comes with only 3 and they are all lifetime warrantee...its worth the price
I've had hasport mounts for almost 3 years and have never had a single problem with them. They hold the engine in place very nicely with only 3 mounts.
no.
I recommend Arizona Race & Machine.
They're the only other company (to my knowledge) that uses the SAME CADD designing processes. They look identical to Hasports and use the same polyurethane like hasport. They are made of the same materials as Hasports. They also only cost $280 shipped. These mounts are excellent and I deal with no other. They align the motor like stock. I mean, if u use these mounts, the crank pulley bolt lines up in the stock location as if it were a dseries motor where the black plastic wheel well guard has the hole in it (if you know what I'm saying).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote">hasport
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenEF9 »</TD></TR><TR><TD CLASS="quote">what about the shift linkage? I heard you have to either buy one aftermarket or get one fabricated to fit?
Why is this the case? </TD></TR></TABLE>
Because the stock one won't work. Do a search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">no.
They're the only other company (to my knowledge) that uses the SAME CADD designing processes. They look identical to Hasports and use the same polyurethane like hasport. They are made of the same materials as Hasports. They also only cost $280 shipped. These mounts are excellent and I deal with no other. They align the motor like stock. I mean, if u use these mounts, the crank pulley bolt lines up in the stock location as if it were a dseries motor where the black plastic wheel well guard has the hole in it (if you know what I'm saying).</TD></TR></TABLE>
I'm going to have to recommend these too. There about half the price and idenical to hasport in every way possible.
Hasport is nice but your mostly paying for the name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- »</TD></TR><TR><TD CLASS="quote">what about swapping the subframe from an EF9 SiR?</TD></TR></TABLE>
It won't work, the subframe (part with the steering rack) is RHD, when our USDM cars are LHD.
Snail Tuning
Jan 14, 2005 09:34 AM
typeeg
Jul 19, 2004 08:53 PM
