GSR block with itr valve train and stage 2 comp Cams Should they make much noise?
I finally got my project together a 95 gsr GSR block, type R pistons and vlave train and a set of stage 2 comp cams. I adjusted the valve to factory specs. .007 intake and .008 on the exhaust. But it sounds like the valves are tapping. Is this normal? It's not very loud but it does not sound like a regular gsr. Could it be that the type r valve train is not up to the task of handling the cams? I'm not sure. Any help would be greatly apprectiated. Thanks Bill
im wondering how are the comp cams stage 2 are the worth the money and do they pull hard is it a great investment on power or should i invest somewhere else let me know what you think about those cams thanks
