ST-MAY SHOTGUN Exhaust Installation
Old Nov 24, 2001 | 08:39 PM
Unlimited's Avatar
New User
Default ST-MAY SHOTGUN Exhaust Installation
ST - MAY SHOTGUN (reforming?) Installing!
From インテ R purchase, approximately 1 year and 8 months. At last, in thinking (laughing) step-up it was possible from normal EX.
The muffler " the ST - the MAY " was favorite, but there is no setting for the how 4dr. " The spoon " having tried probably to install helplessly, it increased, but the tail form tend ょ it was and it was the air difficult the trap to apply and it became dismissal. Efficiency being problem not to be, it does, but. (^ ^ Also it is lonesome to be too quiet to that, (laughing) about being, searching the muffler which plays the exhaust sound of the 々, it increased. (By the way I am not roar system. ^ ^ Because of that for a while the quiet of normal, throwing away wanted, being normal for a while, riding, it increased. As for riding this much long with the normal muffler the ネ where is just インテ R.
There in my origin good news.
How, being cheaper than member Matsuno of the TRIC, " the ST - transferring the MAY shot cancer/gun, " it became to be able to receive. As expected, the brand-new muffler was cut, when it pasted with it fails, how it will do being it is not, I jumped directly and you transferred.
This place borrowing, Matsuno thank you for! M (_ _) m
With favor, perhaps, whether in the world it becomes 1 インテ R, the しれません. (The ネ which is exaggerated ^ ^;
Then immediately circumstances of installing in the digest.
* Name of the part of the note vehicle being my study and insufficient, unless you understand, from scantiness of composition ability it became the page which it is difficult to understand. Acknowledgement.
Helping job, when in order to receive, you telephone to the friend whom it has made depending when it is busy, the reply. (Tear)
When it tries probably to work helplessly alone it is accustomed to hearing the story of muffler installing, two another friends with respect to going/participating! It should have it is the friend. (^ ^) /
Being dark, it is difficult to know, is, but height being low, as for me of the デブ being not to be able to dive, piling up 3 foothold boards, making the インテ rise, it increased in with the maneuvers which jack-up F side.
Blowing the lubricating oil spray, it waits for a while, it waits, it waits. After that, it depended on the volt/bolt nut removal of the muffler.
Volt/bolt of the タイコ part the rear came off gently. Problem occurrence! The nut after the catalyst does not come off. Hitting the box wrench with the hammer, the nut group which is not perturbed.
Helplessly electromotive impact wrench appearance! Why inserting angle being only inch size ones, while being narrow, thrusting, in any case huge impact " the ダカダカダカ. "
OK! As expected the sharp-edged tool of civilization. First loosened simply, but the nut slipped from how the 2nd with socket, licked. " Breaking off "
It recovers the air and challenges for the second time with the glasses. The experience person is the expectation which understands, but the nut which is licked once steadily becomes terrible. How will do we who are gone the lawn to do, it will be stunning, but advancing job to here, being not to be possible either to reset to the origin thinking of good idea, the る. " ピーン! " My occupation is the hardware store. Being also the vise plier っ て hand to be, it does, but just this burning (hard, because has tightened is just the る but), it meaning that is not useful, when another tool you have searched, with that TV shopping familiarity (?) There is an easy wrench, are not are or, the ぁ.
Thinking, I myself do not serve such a tool how purpose, it increased. But (being to be able to sell, stock doing, it increases. It is. ^ ^
The wrench was used on the nut in the thinking which clings to also the straw, power of the 渾 body was included and the wrench was turned. Many times, it was not and slid, but as for end miraculously the nut loosening, job you felt at rest reaching up to discontinuance. The between when it passed to here.
The latest leading figure I - the G wrench and, it licks and the っ which sows it is the っ stalk rag nut <- (being っ て I am bad, it does, but (wry smile))
The nut loosening, after that also job moving smoothly, it becomes shot cancer/gun installing, but according to expectation being somewhat short, you thought extension processing is necessary, but you tried the thing and tried attaching that way with っ て thing.
As for being installing possible you were surprised to unexpected thing. But length not being enough after all, the muffler stay of the タイコリヤ part of the shot cancer/gun (?) The shaft interferes to the tow hook of the インテ beautifully, being to be the disturbance, at the set hammer thinks and the っ drill hits it hits, it hits. (Photograph 1) the enemy of the parent it hits in a similar way, it hits, it hits. The partner the shaft of stain, is stubborn. (-_-
Like this, it will become and appearance will receive in the ゃ sledgehammer. As expected also the stain shaft lifting the root, it bent. (ぁ ぁ) how stubborn person. (Photograph 2)
(Photograph 1) at sledgehammer attack the stay which lifted the root (photograph 2) somehow it escaped and could make the place. But the rust of body lower part is terrible, is. (--
When it is the proper 3dr, installing the stay which hooks the muffler to the tow hook, through the traction rubber, you install, the hook of the left side タイコ, but it does not reach. So, this part with quick fix pulled with the wire. (Photograph 3) to that even the anteriorly muffler stay of the リヤタイコ of the shot cancer/gun (this one is the method which hangs the muffler) having been attached, this side installs the private hook to rear stubby and becomes the appearance which is hung, but this it pulled the rubber compulsorily and (photograph 5) , installed. Immediately, installing end (photograph 4) with it becomes, but when it is running for a while and interfering to the body, being to reach the point where sound comes out it does. (Photograph 6) it is running for a while in this state, but the reinforcement pipe of lower arm lower part (the name which is not completed you do not understand) in the rotary limits which are the muffler to resonate, it contacts with the body and it meaning that sound has come out, it is very unpleasant. The muffler the right goes down to that gradually and (the left rises?) Becoming, also the eye which you saw becoming awkward, necessity of processing arose. (--
Photograph 3) quick fix say, the っ せ which is -. (-- (Photograph 4) somehow the kana which becomes, shape?
Already, the air where many degrees dive stopping doing, you brought to the dealer on December 6th and at the time of mission oil exchange the muffler removed the case of lift rise and received, tried in extended job.
Being safely to process to end, it raises
Distance to completion! For shot cancer/gun 4dr. (Laughing)
Well the excessiveness calling to the dealer, (?) At the time of mission oil exchange the case of lift rise, looking at the opening of the dealer, (. Is joke but) the muffler was lowered for the second time.
# When as expected it lifts raises the っ shank where job progresses. Jacking-up, the fact that it dives in the narrow インテ and suffers hardship was what. (^ ^
* The picture being many, it is heavy expectation. Acknowledgement. M (_ _) m
So it is everyone expectation, the っ the り it is the shot cancer/gun which was said. The original owner certainly cries, probably will be. (^ ^
Inside of the muffler was rusted in being surprised. Because it is exposed to severe environment certainly, don't you think? the ぇ. (- -
Plant manager of my company (?) Welding, you received. (^ ^ And, painting also the anti-corrosive, you completed nicely. (^ ^) v
Being to extend on rear side, the oven doing the spacer, measure it does that the excessiveness depended on the muffler ring.
# But don't you think? it is the enormous rust, the ぇ. (- - Unless with Okinawa the subordinate work it rusts and stops like the picture above it rusts, it is is.
* To special performance you taking care, the president of る stone wall HONDA 4 wheel service (the upper left photograph burner having, る one) is. (^ ^) /
Roasting with the gas, it bends the muffler side stay, but the job bee ょ it is underneath the fuel tank, fear. (- -
And it came off and completed also balance nicely.
Just a little it is vague, is, but there is no strange feeling and was attached cleanly. (^ ^) v
Old Nov 24, 2001 | 08:45 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: ST-MAY SHOTGUN Exhaust Installation (Unlimited)
This would be a good post if you had translated correctly. I am guessing that was all either in Japanese or Chinese originally?
edit - it must be Japanese, I just looked at the pics more closely and there are some Hirigana and Katakana as well as Kanji.
[Modified by Ross1013, 5:47 AM 11/25/2001]
Old Nov 24, 2001 | 08:49 PM
Dee's Avatar
Dee
ummm... Why are you posting a semi translated page of the Shitgun muffler that has a life expectancy of less than 6 months once installed. Cancer(rust) kills this uncoated mild steel piping REALLY quick!
Old Nov 24, 2001 | 09:12 PM
S13Koop's Avatar
Default Re: ST-MAY SHOTGUN Exhaust Installation (drealgsr)
An ITR owner here in Houston has that exhaust, wonder how he got it installed. Doesn't last long eh? wonder if he knows that...
Old Nov 24, 2001 | 09:15 PM
IN VTEC's Avatar
Default Re: ST-MAY SHOTGUN Exhaust Installation (winglessR)
Can't be very long when the B-pipe is scraping the ground 24/7.
Old Nov 24, 2001 | 09:16 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Active Streak: 60 Days
yeah that looks like crapand it gives me a headache to read.
Old Nov 24, 2001 | 09:20 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: ST-MAY SHOTGUN Exhaust Installation (Rguy)
Yeah tell me about it - "regarding exhaust posting on Honda-Tech messaging board headache is giving"
Brian - sign up for VIR dammit! 4 more people including you!
Old Nov 24, 2001 | 09:21 PM
Dee's Avatar
Dee
I just noticed that this is an Okinawa 96spec R. I wonder why I haven't seen it rolling around town?? I have seen that Honda Beat with the R stickers though!
Old Nov 25, 2001 | 06:05 PM
done's Avatar
tight???
i think its kidna cool...
Old Nov 25, 2001 | 06:36 PM
Cosworth's Avatar
Default Re: ST-MAY SHOTGUN Exhaust Installation (Jordo)
I very well not understaning whut was said. Ittt is a 4-doe aRu, eh!
Old Nov 25, 2001 | 07:34 PM
Phoenix-R's Avatar
New User
oh c'mon man, it does'nt look that bad.i've had it for about a year and a half now,and I have no problems with it.well I had to cut the B-pipe b/c it's a JDM exhaust,and I just bent some of the pipes and it was fine,but seriously it looks bad if you look at it from the bottom,but if you loook at it from standing up- it would look pretty nice.well i have it and its not so bad, I have'nt had any problems with it.but everyone is entitled to their own opinion.
Old Nov 25, 2001 | 07:56 PM
Dee's Avatar
Dee
Default Re: ST-MAY SHOTGUN Exhaust Installation (Phoenix-R)
Ok... the problem with the Shitgun is the uncoated low grade steel piping that rust at an accerelated rate once installed on the car. Looks cool but is actually poorly designed.
Old Nov 26, 2001 | 08:23 AM
Phoenix-R's Avatar
New User
I agree with you on the poorly designed part, but it doesnt rust as bad as you say it does.
Old Nov 26, 2001 | 08:26 AM
Phoenix-R's Avatar
New User
well this is how my shitgun,I mean shotgun exhaust looks on my car.
Old Nov 26, 2001 | 08:29 AM
yoshi234's Avatar
I shoot brides
かっこいいけど、ちょっと それ ひ*いんじゃないかな 。
佳 - 日本語 ちょっと 分かる
Old Nov 26, 2001 | 08:43 AM
DutchITR1689's Avatar
Default Re: ST-MAY SHOTGUN Exhaust Installation (yoshi234)
かっこいいけど?Aちょっと それ ひ*いんじゃないかな ?B
佳 - 日本語 ちょっと 分かる
Yeah, I totally agree.... @#$%^&*~
Old Nov 26, 2001 | 08:45 AM
yoshi234's Avatar
I shoot brides
Default Re: ST-MAY SHOTGUN Exhaust Installation (EuroITR1689)
LOL! you have to turn on your Japanese encoder on your brower setting
Old Nov 26, 2001 | 08:50 AM
Do you think that would make a difference for me? This makes me remember an image with some fake chinese characters, but when you turn it 90 degrees it reads "GO **** YOURSELF". Anyone seen that or have that?
Old Nov 26, 2001 | 08:57 AM
project_DC2's Avatar
ehhh... same here>..........Henrys exhaust has lasted about 3 yrs more expentency than ever!
Go to http://www.jspek.com
More pic. are there!
[Modified by project_DC2, 5:59 PM 11/26/2001]
Old Nov 26, 2001 | 09:59 AM
6SPD_EK's Avatar
mmmmmm.....4 door ITRs (drool all over keyboard)mmmmmm...
Old Nov 26, 2001 | 12:26 PM
mugenr#1011's Avatar
Default Re: ST-MAY SHOTGUN Exhaust Installation (project_DC2)
yeah plus henry was the first person to get one in the u.s i beleive.....plus he is cool....so dont hate congradulate
Old Nov 26, 2001 | 01:26 PM
SpecR_EK's Avatar
New User
Default Re: ST-MAY SHOTGUN Exhaust Installation (mugenr#1011)
Anyone know if the original poster is Japanese? Seems like that was his car that he was posting about.
Btw, Yoshi: were you commenting on if his exhaust hung low? *Understood most of his post except the last part*
[Modified by SpecR_EK, 2:32 PM 11/26/2001]
Old Nov 26, 2001 | 02:29 PM
nsx-Animal's Avatar
Default Re: ST-MAY SHOTGUN Exhaust Installation (SpecR_EK)
Great now instead of having one grapefruit shooter you have 2..
Old Nov 26, 2001 | 05:30 PM
R spec's Avatar
New User
Default Re: ST-MAY SHOTGUN Exhaust Installation (ITR-Animal)
damn!...they are too big!....
Old Nov 26, 2001 | 06:22 PM
Cyrio's Avatar
Default Re: ST-MAY SHOTGUN Exhaust Installation (R spec)
Dual exhaust, even if its in the middle of the car, doesn't look right on Integra's.
thambi23
Mar 20, 2008 06:06 PM
ke98248
Mar 3, 2007 10:51 PM
bigcujr
May 28, 2004 12:19 AM
