VTEC activation trouble
Old Jul 19, 2004 | 11:09 AM
11sec CR-X's Avatar
Default VTEC activation trouble
I just replaced the head gasket and timing belt on my daily driver its a b16 in a four door. I replaced it last night and set the timing the car drives good and everything. Put the cams straight up used the old screw driver throught the cam holes trick and crank at tdc then installed the belt. But Im still having the same problem I had before the replacement of the parts. I put the foot down slowly just to see if vtec will activate and its not well it sounds a little but rpm is moving slow when VTEC should activate. I sometimes will fuel cut down like hitting the revlimit. I have swapped the vtec solenoid from my CR-X and still nothin. Swapped ecus nothing. The things wrong with it is the speed sensor and the rpm fluctuates. Could this be the map or tps sensors if so would that cause the shitty VTEC. I thought it was the timing at first but swapped and reset everything and now Im stumped. Just thought someone here would spark my mind.. thnx CHRIS
Old Jul 19, 2004 | 12:51 PM
Junkiii Ek's Avatar
Default Re: VTEC activation trouble (11sec CR-X)
did u try swapping the Dist.... try that out and post results...
Old Jul 19, 2004 | 06:26 PM
11sec CR-X's Avatar
Default Re: VTEC activation trouble (Junkiii EJ8)
Thnx Ill give it a try see what happens. Ill let you know.
Old Jul 19, 2004 | 06:58 PM
HoOridin's Avatar
fix speed sensor first and go from there...ecu has to see a certain speed to actitvate vtec..
Old Jul 20, 2004 | 02:08 AM
Junkiii Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11sec CR-X &raquo;</TD></TR><TR><TD CLASS="quote">Thnx Ill give it a try see what happens. Ill let you know. </TD></TR></TABLE>
any results yet??
Old Jul 20, 2004 | 03:11 AM
T.J.'s Avatar
Just wondering if your throwing any codes.
Old Jul 20, 2004 | 05:36 PM
11sec CR-X's Avatar
Man I didnt get to check the distributor. I will very soon, just work kept me busy today. I appreciate everyones help. I havent checked the codes yet. When ever my speed sensor started to act up my VTEC did start acting up to either coincidence or it could be the culprit. We shall see I shall keep everyone posted. THNX
Old Jul 21, 2004 | 12:38 AM
Junkiii Ek's Avatar
Default Re: (11sec CR-X)
Old Jul 21, 2004 | 03:37 AM
93H22ACX's Avatar
Default Re: (Junkiii EJ8)
speed sensor...had it happen to my prelude when i still had her
Old Jul 21, 2004 | 05:59 PM
11sec CR-X's Avatar
It has been confirmed (speed sensor)I figured it was it but didnt have another one to test it out but I found an old one that had eatin up gear teeth swaped over the shaft from the faulty one and wow VTEC. Thnx for all the confirmations. And help. I figured it was since it seemed to happen at the same time speed sensor and Vtec trouble thanks guys.
tommychong
Apr 1, 2013 05:30 PM
SPEED FoRCE
Jan 14, 2010 05:06 AM
cloudconnected85
Oct 4, 2008 07:32 PM
F20BEK
Feb 11, 2008 11:27 AM
GreenGSR
Jul 28, 2002 07:12 PM
