Cam Gear Install Question
I am about to install cam gears on the GSR that i recently bought and i see that the top of the timing belt cover has been cut off.. so how can i possibly make sure that everything is at TDC.. i can do that crank one because the bottom of the cover is still there however the top is not.. how do i make sure the cams are i the correct position? are the keyway holes supposed to be straight up?
Thanks
Dan
Thanks
Dan
You can put something in the cylinder that rests on top of the #1 piston to determine what is TDC. A long screw driver or something.
And heres a pic of how the cam gears should line up. Its easier to line up the middle marks (TDC marks) instead of the Up arrows, they will point slightly forward.
