DA rear disc brakes
yea thanks i saw that its a pretty good dia. , but i feel like im gonna have problems w/ the brake lines and/or e-brake cables and/or prop valve which makes me not wanna do this swap.
I really want to do this also since i already installed DA front brakes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOnDadiCt »</TD></TR><TR><TD CLASS="quote">yea thanks i saw that its a pretty good dia. , but i feel like im gonna have problems w/ the brake lines and/or e-brake cables and/or prop valve which makes me not wanna do this swap.
I really want to do this also since i already installed DA front brakes</TD></TR></TABLE>
Do that ****
It's extremely easy if you follow the pic.
If you have a problem we'll help you.
imo the rear is easier than the front.
I really want to do this also since i already installed DA front brakes</TD></TR></TABLE>Do that ****
if you installed the front yourself, the rear + p. valve should be a piece of cake.
I really want to do this also since i already installed DA front brakes</TD></TR></TABLE>if you installed the front yourself, the rear + p. valve should be a piece of cake.
I did a reverse rear disc swap on my civic and put the drums back on in place of the discs last week and I would say it took me only about 2 hours to do this time. Everything is pretty easy.
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
It really is pretty easy as others have mentioned..........but gotta question for ya.....when you did the fronts......did you use the DA of EX knuckles? I still have been unable to find the truth to being able to use DA knuckles.
If you run into any prob's with the rears......shoot an IM
I really want to do this also since i already installed DA front brakes</TD></TR></TABLE>It really is pretty easy as others have mentioned..........but gotta question for ya.....when you did the fronts......did you use the DA of EX knuckles? I still have been unable to find the truth to being able to use DA knuckles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. B in Az »</TD></TR><TR><TD CLASS="quote">
If you run into any prob's with the rears......shoot an IM</TD></TR></TABLE>
If it helps, I went with DA knuckles and the drive is ok, no problems so far. Just make sure to get an alignment after.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
x 2 for me. no problems hear and yes, get an alignment afterward
</TD></TR></TABLE>x 2 for me. no problems hear and yes, get an alignment afterward
I got my jdm DA complete front knucles from Steve at HMO
I took off my shitty USDM STD ones and swaped these right on , easy bolt-on. Way better response and braking
I didnt get an alignment though so this explains why my MOMO Team steering wheel isnt straight when i am driving
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote">no write up, but this shows you everything u gotta remove
Why did you say: this picture shows everything you got to remove.. but it says: "do not remove" that one bolt... does just the bolt help alignment?
</TD></TR></TABLE>Why did you say: this picture shows everything you got to remove.. but it says: "do not remove" that one bolt... does just the bolt help alignment?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four »</TD></TR><TR><TD CLASS="quote">Why did you say: this picture shows everything you got to remove.. but it says: "do not remove" that one bolt... does just the bolt help alignment?</TD></TR></TABLE>
that bolt holds in your stock c-arms and yes, allows for alignment. sometimes people remove the stock crx c-arm and replace it with the one that comes with their new disc-trailing arms. you NEED to use the crx c-arms or else correct alignment will be impossible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four »</TD></TR><TR><TD CLASS="quote">ohhh I get it... does this picture also apply it 88's, becuase I know that our lower control arms and shock mounts are different.</TD></TR></TABLE>
yes it applies to 88's
Last time I was at the junkyard I checked the DC trailing arm numbers against the DA and they were exactly the same.
I've got a set of DC arms in my room waiting to go on my EF; hopefully they'll work. From what I can tell they are absolutely identical to the DA's in every important measurement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16tripod »</TD></TR><TR><TD CLASS="quote">does any one know if DC trailing arms will work on an EF</TD></TR></TABLE>
That is what I am using. 94-01 Integra will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phan »</TD></TR><TR><TD CLASS="quote">
you NEED to use the crx c-arms or else correct alignment will be impossible.</TD></TR></TABLE>
You can get correct alignment with any 88-00 civic or 94+ integra compensator arm. It is impossible if you use DA c-arms. The DA c-arms are about 1" longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">Last time I was at the junkyard I checked the DC trailing arm numbers against the DA and they were exactly the same.
I've got a set of DC arms in my room waiting to go on my EF; hopefully they'll work. From what I can tell they are absolutely identical to the DA's in every important measurement.</TD></TR></TABLE>
only difference is the trailing arm bushing. It's slightly bigger. Everything else is the same.
Get a 10mm flare nut wrench so you don't strip the flare nuts.
<FONT SIZE="4">The two bolts for the trailing arm bushing pin get torqued to 69 ft.lbs not 47 ft.lbs</FONT>
racer_X_123
Mar 24, 2006 09:37 PM
89dxhunchback
37
Jan 1, 2005 12:07 PM
