Fuel cut on P73 Jdm ITR ECU?
Old Jul 18, 2004 | 02:14 PM
SilverEk3dr's Avatar
Default Fuel cut on P73 Jdm ITR ECU?
I searched, but I just cant find what fuel cut is on the P73. Just got it so I can use it on my gsr swap. Thanks in advance
Old Jul 18, 2004 | 02:25 PM
esponet's Avatar
84ish but might read 9k on your stock tach
Old Jul 18, 2004 | 03:40 PM
uNF$@#!'s Avatar
Default Re: (esponet)
84ish for a fuel cut?
its same fuel cut as us spec.
Old Jul 18, 2004 | 03:53 PM
obd2gsr's Avatar
Default Re: (Captain Commando)
give or take, it is around 8400.
and 6500 in 5th gear
Old Jul 18, 2004 | 03:59 PM
esponet's Avatar
you can't go by a tach to decide were the rpm cuts. from the time between the ecu cuts the fuel to the time the motor react it would have been about 200rpm later. not to mention most honda tach are off. hence my spoon tach is off by 400ish rpm.
Old Jul 18, 2004 | 04:11 PM
what??? It has a speed limiter?
son-of-a.....
Old Jul 18, 2004 | 04:15 PM
esponet's Avatar
yes, about 185km/h so thats about 120mph??? anyways it was about 7500rpm on my 5th gear.
but the rpm cut is about 84is some say 86 but 200 rpm is too small of a difference for me.
Old Jul 18, 2004 | 07:35 PM
Girl's Avatar
How sure are you about this?
I got the stock ECU and I've been up to 8600rpm and past 120mph...
Old Jul 18, 2004 | 07:39 PM
esponet's Avatar
well mine cuts were i said it cuts. i'm sure not all ecu are exactluy the same. btw were talking about jdm ecu's. usdm ones does not cut that low.
Old Jul 19, 2004 | 12:13 AM
sylvain's Avatar
Default Re: (Girl)
The fuel cut is the same as the EUDM P73: 8600rpm and 8900 on tach.
Old Jul 19, 2004 | 03:59 AM
Jdm 98spec R's Avatar
Default Re: (sylvain)
My stock ecu had a speed limiter.. around 190-200 kmh..(jdm ecu)
Old Jul 19, 2004 | 04:01 AM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">yes, about 185km/h so thats about 120mph??? anyways it was about 7500rpm on my 5th gear.
but the rpm cut is about 84is some say 86 but 200 rpm is too small of a difference for me.</TD></TR></TABLE>
I cant tell you what rpm it stops at in 5th b/c i have never actually paid attention to it but i know for sure that the jdm 96&97 spec p73 is governed at approx 127 mph area. It was 3 a.m on open highway for all who are wondering WHY I WAS TRAVELING AT SUCH SPEEDS !
Old Jul 19, 2004 | 06:06 AM
2kgs-R's Avatar
Default Re: (B18C-Rsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">
I cant tell you what rpm it stops at in 5th b/c i have never actually paid attention to it but i know for sure that the jdm 96&97 spec p73 is governed at approx 127 mph area. It was 3 a.m on open highway for all who are wondering WHY I WAS TRAVELING AT SUCH SPEEDS !</TD></TR></TABLE>
This is true, I'm currently using an jdm p73, the fuel cut is around 8400rpm, and the speed limiter is approx. 120mph, but it looks like 130mph on the stock tach. The stock tach is pretty inaccurate after 100mph.
Old Jul 19, 2004 | 06:12 AM
aznboysrfr's Avatar
that's really gay for the tach to be off 3-400 rpms!
Old Jul 19, 2004 | 06:18 AM
sylvain's Avatar
Default Re: (aznboysrfr)
My fuel cut is at 9100 on the mugen ECU and 9600trs on the tach
LillDragun
Jan 21, 2003 10:49 PM
itr1244
Sep 15, 2002 09:16 PM
Tommy_Gunns
Jul 28, 2002 03:11 PM
AL
Nov 15, 2001 11:17 AM
HX_Guy
Aug 6, 2001 12:01 PM
