Info on a b20 project...
Old Jul 18, 2004 | 01:50 PM
Baggy Spandex's Avatar
Default Info on a b20 project...
Whats up fellas....
After some long thought about my ls/vtec project that i want to start, i decided to go B20/vtec. What I want to know is if I can use a b20z from an older prelude SI, as opposed to a newer b20b from a CRV. Is there any benefits/drawbacks to using this z block if i can?
And also, a b20 setup with a b16a head, is this basically the same procedure as doing an ls/vtec as far as motor mounting goes...i know i still have to run the oil lines and i was going to contact AEBS about their dowel pin kit and use the golden eagle ls/b2o vtec kit. So basically all im asking is if i can use ls mounts and whatever tranny i use, use the respective axles?
Old Jul 18, 2004 | 06:49 PM
Propulsion's Avatar
Default Re: Info on a b20 project... (OneFiveAlive)
prelude had the b20a, which is junk
B20b comes in pre-99 crv's usdm or jdm
B20z is the 99-01 Crv motor.
B20z has 9.6 compression B20b has 8.8.
If you don't plan to change the pistons, go w/ the b20z
You are right about the mounts, the B20 is basically a bored out LS, so no external differences.
Old Jul 20, 2004 | 07:17 PM
ImajinAZN's Avatar
what makes the z higher compression than the b? z motors are very hard to come by for a reasonable price so im looking at the b20b for now
e-g-6jdm
15
Nov 11, 2007 03:06 PM
hondachris1994
Mar 24, 2006 07:18 AM
IntegraGSR(-1)
Jul 10, 2005 09:52 PM
TwistedHatch
Aug 17, 2003 06:54 PM
