gsr cluster swappers, is this missing a connector or not?
Old Jul 18, 2004 | 10:22 AM
b16_madman's Avatar
Default gsr cluster swappers, is this missing a connector or not?
It's a good price, but if it's missing somethin I need, then I don't care to mess with it, since every wiring shematic I've read doesn't work for everyone, but I really enjoy these clusters since the tach is most correct for the b16 er whatever, and lights up better at night, and the higher speedo doesn't hurt either.
http://cgi.ebay.com/ebaymotors...33675
see the backs of the clusters pic?
to the left of the right connector it seems to have a connector missing, or am i just dumb and it's not needed??? errr, i'd think it is, but I did read something about that manual clusters didn't need this?
Old Jul 18, 2004 | 10:26 AM
b18apwr's Avatar
Default Re: gsr cluster swappers, is this missing a connector or not? (B16_madman)
I did this cluster swap. You are fine. I believe that the missing plug is where the automatic indicator lights, etc. plug in. I only used the two big plugs in each corner of the cluster and everything (except the low fuel warning light) works on my CRX. I've got a spreadsheet that I made with the pinout info if you need it.
Old Jul 18, 2004 | 10:46 AM
0554's Avatar
yes the missing one is for automatic lights. you are fine. the swap is easy as hell. to me 20 minutes to install it. i didnt use anybody's diagram. i just traced everything on the back of the gauge clusters myself. that took like 45 minutes.
Old Jul 18, 2004 | 11:19 AM
krazie1's Avatar
BANNED
Default Re: (88crex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crex &raquo;</TD></TR><TR><TD CLASS="quote">yes the missing one is for automatic lights. you are fine. the swap is easy as hell. to me 20 minutes to install it. i didnt use anybody's diagram. i just traced everything on the back of the gauge clusters myself. that took like 45 minutes.</TD></TR></TABLE>
so I guess it took 1hr and 5 mins
correct&gt;&gt;&gt;??
45 mins. to trace wires back plus 20 mins to install....
yeah it took me about the same to do my si-R cluster
just as long as u got the clips and can tell colored wires apart then it should be easy as pie
Old Jul 18, 2004 | 11:37 AM
DsMWookie's Avatar
Default Re: (krazie1)
b16_madman here: well that's good to know, dang now i showed you all the cheap gsr clusters
Old Jul 18, 2004 | 04:08 PM
0554's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">
just as long as u got the clips and can tell colored wires apart then it should be easy as pie </TD></TR></TABLE>
yes took about an hour to install. i didnt match wire colors. i just matched pin locations. i didnt care about colors.
Old Jul 18, 2004 | 06:13 PM
b16_madman's Avatar
oh yeah and those w/the 88-89 civic/crx lemme know which writeup you used to do this, and if you know what year the teg cluster was also, that'd be great
I'll prolly try color matching wires first, then test it
Ray Satomi
11
Apr 27, 2017 09:05 PM
worx
Nov 7, 2012 06:10 AM
integraXTC
10
Jun 12, 2011 02:43 PM
EGJdmJreams
22
Nov 12, 2004 01:59 PM
^Sammy]!.
13
Mar 5, 2003 06:09 PM
