OBD1 swap: intermittent injectors...
I'm swapping a d16z6 into my car as we speak..but the injectors dont seem to be consistently firing...sometimes they work, sometimes they dont. everything seems to be connected right and I'm using the OBD1 injectors...any ideas? thanks.
Have you checked your grounds??? Have you had someone check over your wiring for you? Have you tried a different set of injectors? If none of this works then I am clueless to why the injectors would not be firing.
now that I've been thinking about it...I kinda think there's a ground that I left out and I think its on that section of the harness so that's my big culprit now...I tried two different sets of injectors.... thanks guys.
