Suspension For a gsr
i've read up and searched but people always said different things..
i have about 500 to spend on suspension i want both springs and shocks, i dont want any fender gap but i also dont want it to rub, 15in Rims.
with that money, i suggest you get neuspeed koni yellows only. With that shock and on the lowest perch with your stock springs, it should be a perfect drop, and will still ride like stock if you want, or ride stiffer wth the twist of a ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling »</TD></TR><TR><TD CLASS="quote">with that money, i suggest you get neuspeed koni yellows only. With that shock and on the lowest perch with your stock springs, it should be a perfect drop, and will still ride like stock if you want, or ride stiffer wth the twist of a ****. </TD></TR></TABLE>
where can i get some Koni's?
importhorizon.
Going koni is the best way.. that way you lower it correctly and with great shocks.. and if for some reason you feel your ride is not stiff enough, that leaves room to get aftermarket springs in the future if you want.
goto my website I have neuspeed springs and I am SLAMMED if you want that look try htose, the only thing is bumps on the road KILL your car, http://www.cardomain.com/id/bboynekro
My shock and spring combination cost me about $425. It consists of:
KYB ABX shocks: $295 shipped
H&R OE springs: $125
The OE springs give a .75" drop and get rid of most of the fender gap. I've been riding on this setup for 15K miles without any problems or rubbing.
http://www.shox.com
Free shipping too and located in San Diego, Ca :D
that's where I got the koni yellows for the rear of my GSR :B
-aoib0t, who is glad he finally got his hair cut
BoostinEJ1
17
Jan 9, 2004 11:22 PM
reVVin
Mar 17, 2002 09:24 PM
no fender gap, sits right on tire with no rubs. Had 15's too....
